running 12 pinon
RichJ
Topic author - Posts: 372
- First Name: Rich
- Last Name: Jesteadt
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1913 Touring project w. "A" crank shaft
running 12 pinon
Has anyone had experience with running 12 tooth pinon with 40 tooth ring ?
Langs website says NOT FOR USE WITH 40 tooth ring gear.
Thanks in advance.
Thanks in advance.
Re: running 12 pinon
Yes. I am sure they are saying a 40 T from a 11:40 set. That's correct. 12T gear is large diameter & has to be used with an offset hi speed gear. 39 or 40T rux gear. This does require a tall shim to raise the ring gear, about 1/8" Now you risk shearing gear bolts. Running this now. time will tell.
The best answer has to be some creative shifting of the carrier(non rux) A stock 40 T gear is certainly possible with machining the bell(rux), but not simple.
nigel_hugo
- First Name: nigel
- Last Name: hugo
- * REQUIRED* Type and Year of Model Ts owned: 1911 T touring car
Can I run a 12 tooth pinion with a 39 tooth ring gear in a Ruckstell axle. I have run the ring gear with a 13 tooth pinion but it is too highly geared and I want to bring the ration close to 3.25:1.
Thanks in advance.
Nigel Hugo.
Thanks in advance.
Nigel Hugo.
YES.nigel_hugo wrote: ↑Wed Nov 03, 2021 3:43 pmCan I run a 12 tooth pinion with a 39 tooth ring gear in a Ruckstell axle. I have run the ring gear with a 13 tooth pinion but it is too highly geared and I want to bring the ration close to 3.25:1.
Thanks in advance.
Nigel Hugo.
This my set up (Above post) Did require me to make a special thick spacer for proper gear mesh.
Nigel, I have just that setup in my 25 roadster, with no extra spacers or shims. I set all my rear ends up making adjustments to gear mesh by varying the thickness of the standard Ford thrust plates and the bronze thrust washers supplied by the vendors.
Hope this helps.
Hope this helps.
RichJ
- First Name: Rich
Are all 39 tooth ring gears offset?
Thanks for the replays .
JSteele
- First Name: John P.
- Last Name: Steele
- * REQUIRED* Type and Year of Model Ts owned: 1915 Roadster
I used a a 39 tooth ring gear with 12 tooth pinion, no special spacers. Ring gear came from one of the vendors. I have a Jumbo Planator under drive in front of it, works great.
I found the need for a spacer to raise this gear in a RUX. Other wise the mesh was to loose. Moving the carrier would take serious, unnecessary, re-engineering.
If I do another rux with a 12t gear, I will likely try to use a standard 40t ring & trim the carrier bell considering:
1) Will it mesh well? 2) Can I successfully shorten the correct ring gear bolts.(enough extra thread length.)
- First Name: craig
- Last Name: leach
Just a note, ring and pinion sets should have one odd number. If there is two even numbers then there is a regular repition in the teeth contact and can cause undesirable wear patterns over time.
Mark Chaffin
- Last Name: Chaffin
Allan is spot on for both the 39 and Ruckstell 40.Allan wrote: ↑Wed Nov 03, 2021 11:43 pmNigel, I have just that setup in my 25 roadster, with no extra spacers or shims. I set all my rear ends up making adjustments to gear mesh by varying the thickness of the standard Ford thrust plates and the bronze thrust washers supplied by the vendors.
Hope this helps.
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
"Are all 39 tooth ring gears offset?"
Yes they are.
40 Tooth Ruckstell ring gears are also offset.
40 Tooth Ford Ring gears are NOT offset.
Yes they are.
RichJ
- First Name: Rich
THANKS to all for there information.!!!
Is there a remote possibility any one would have a 39 tooth they would part with ?
