I Almost Threw This Useless Screwdriver Away….
MichaelPawelek
Topic author - Posts: 712
- First Name: Michael
- Last Name: Pawelek
Re: I Almost Threw This Useless Screwdriver Away….
It's a Godsend when you need one.
If you don't have that, you can do the same thing by putting a screw on the screwdriver with a piece of tape.
- Last Name: Hatch
In shop I started in years ago, we called them Monday Morning Screwdrivers.
Cap
- First Name: Cap
- Last Name: Weir
- * REQUIRED* Type and Year of Model Ts owned: 24 & 25 C Cab
I prefer this type.. Gets into smaller spaces, and will screw hold upon extraction..
This is the one I use on the cover..
https://www.mcmaster.com/screw-holding- ... e~slotted/
Cap
Cap
- First Name: Dennis
- Last Name: Seth
I have used screwdrivers like that for years. I picked mine up at the electrical supply house and use it to hold the ground screw or other screws deep inside an outlet or light switch box. They work great when working overhead applying covers on junction boxes etc.
- Last Name: Wrenn
I USED to have one.
Sadly, I lost it.
I need to get another one. they're super handy.
I got one from McMaster Carr.
George Mills
- Last Name: Mills
Like Tim, I use to have one. It was the two blade slide sleeve type with a really long shaft. Worked great. Somebody wanted it more than I did.
I now have one of the spring clip kind and they work well...just a bit tight for stubby fingers...
John Codman
- Last Name: Codman
I do too, but we have both.Cap wrote: ↑Thu Nov 11, 2021 7:56 amI prefer this type.. Gets into smaller spaces, and will screw hold upon extraction..
Cap
Mikey1968
- Last Name: Jewell
You can also use a dab of EZ Turn fuel proof grease as it's pretty sticky stuff. I've started nuts that I could only get my finger tip on it by putting a dab on my finger tip and sticking the nut to it.
- Last Name: Seth
The problem with using sticky grease is that as soon as I put it on my finger my nose becomes itchy and I always use the finger with the grease on to scratch it!
I jam the head of the screw in a short bit of rubber fuel line, then use an ordinary electrician's screwdriver poked down the fuel line. Works a treat.
Mark Osterman
- Last Name: Osterman
The old trick was slipping a short piece of thin rubber tubing over the end of the screw driver to hold the screw.
Mikey1968
- Last Name: Jewell
Itchy nose to grease issue!
Been there! What's worse is when you get a dob of silver anti-seize on your fingers and don't realize it. You get silver all over the place and yourself!
