Top Bow Fabric
Topic author - Posts: 2294
- Last Name: Juhl
Top Bow Fabric
I have yet to try to install a top on my 1917 touring. There are plenty of other things that need to be done first. My question is this... I've been told that the wood portion is normally wrapped in black fabric, but mine are wrapped in white. The fabric looks really old telling me it's been on the car a long time...maybe original.
What is supposed to be used to wrap the bows?
- First Name: Erik
- Last Name: Johnson
Re: Top Bow Fabric
Although the original bow drill and interior side of the top was tan, your cloth does not look original to me. Too light and too much puckering.
Today, most folks use black bow drill.
The first/front bow is wrapped in leatherette. The leatherette is cut on the bias to eliminate puckering.
The next three bows are covered with bow drill which is cloth cut on the bias so it does not pucker.
The cloth for the second and third bows is sewn and not tacked to the tops of of the bows. Tacks will wear through the top material.
Photo below is from an unrestored, almost zero mileage June 1917 touring, AKA "the Rip Van Winkle" Ford.
Re: Top Bow Fabric
Totally agree with everything Erik states. Will add the the bow drill material should extend onto the bow socket just enough to almost meet the edge of the top. The ends of the bow drill are then turned under to create a nice, finished and even end. Kind of like a hem.
- Last Name: Juhl
Re: Top Bow Fabric
Very helpful Erik. Are tacks used to attach any of the wraps to the bows before the top is installed or are they all sewn? Is the wood of the bows unpainted, painted, varnished? Also, how much of the wood is left unwrapped above the metal part of the bows?
Re: Top Bow Fabric
The bow drill is also used to make the pads.
- Last Name: House
Re: Top Bow Fabric
Yeah, thanks Erik....I was wondering about that too. Do I just go to the big city upholstery store and ask for “bow drill” and they’ll know what I’m talking about? And I didn’t know about ‘cut on the bias’ either. Thanks again. I’m making a top for a ‘10 Maxwell runabout. Will use that cobra material because it looks older than long grain....
- Last Name: Juhl
Re: Top Bow Fabric
Two questions -[1] how are the wood bows supposed to be attached to the steel tubes of the top frame? [2] Is there a good supplier of replacement wood top bows? Some of mine are less than perfect.
- First Name: R.V.
- Last Name: Anderson
Re: Top Bow Fabric
My brother makes the wood bows from the Ford drawings. Email him at jpautowood@gmail.com or phone him at 716-985-5880.
- First Name: R.V.
Re: Top Bow Fabric
To answer your other question, the bow ends are shaped to fit tightly into the socket ends using a spoke shave or draw knife. Lacking those, you can use a disc sander. You want a sort of "glass stopper" effect so the bows once driven in are hard to get out of the sockets. You do need a tight fit so the bows don't wiggle in the sockets and ultimately tear the fabric. A large upholstery tack is driven in once the bow is where it belongs, just for added security.
According to Ford, the ends of the first and fourth bows are driven 7" into the sockets, and #2 & 3 are driven 5".
- First Name: R.V.
Re: Top Bow Fabric
- First Name: R.V.
Re: Top Bow Fabric
Apologies for the double post. Dunno what happened.
Re: Top Bow Fabric
Restating my posting, just above yours, "Will add, that the bow drill material should extend onto the bow socket just enough to almost meet the edge of the top. The ends of the bow drill are then turned under to create a nice, finished and even end. Kind of like a hem."
In other words, NONE of the wood should show.
Re: Top Bow Fabric
When I'm wrapping that front bow, I have a jar of contact cement to hold everything in place. As easy as it looks, this isn't an easy job.
- First Name: Adam
- Last Name: Doleshal
Re: Top Bow Fabric
I’ve seen black, brown, and off-white bow wrapping and padding on various cars (new and old restorations and originals). I am thinking that bow wrapping & padding was originally black from Ford and naturally bleached itself out over the years? I’ve also seen white stitching in tops that were over 60 years old and figured the same thing happened.
- Last Name: Juhl
Re: Top Bow Fabric
After I took the old rotten fabric off the bows I decided that the existing bows should be replaced. When I put them back together I want to do it right so that raises the question of how to prep the wood before covering with fabric.
What do you recommend? Linseed oil, spar varnish, paint...??
- First Name: Erik
Re: Top Bow Fabric
Unless the original wood bows are actually rotten, I would not replace them.
There is nothing painted on the wood top bows and there no reason to treat or coat them.
- First Name: Jim, Sr.
- Last Name: Rodell
- * REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
Re: Top Bow Fabric
If your bows are just full of holes from the tacks used on previous tops you can fix that. Get a box of round toothpicks and cut them in half with a wire cutter. Dip them in wood glue and tap them into the holes. After the glue dries nip them off close to the bow. Now sand everything smooth with a belt sander.
1922 Coupe , 1926 Touring
- Last Name: Juhl
Re: Top Bow Fabric
I thought my wood bows were OK until I took the fabric off. Rot, cracks, delamination, warps & more holes than in a woodpecker colony. I found where two had been repaired (poorly) and another replaced with a laminated piece where you could see daylight between the laminations on the bends. I had a woodworker friend inspect them and his recommendation was to replace and I agreed.
Jim, yours look a whole lot better than mine.
I could probably get by with them for a few years but I only want to do this once. When I finish with this car I hope to spend more time driving it than making repairs.
- First Name: Dallas
- Last Name: Landers
Re: Top Bow Fabric
Tim, Tim! When you get that one done its time for another my friend. Did we not explain this model T thing?
I replaced all the wood in my RPU and its not a bad job. The help here on the forum will get you through it.
- Last Name: Juhl
Re: Top Bow Fabric
Dallas - that's why I need to finish this one in case I wish to turn my attentions elsewhere
In the meantime I'll have a good Model T to tour with.
Re: Top Bow Fabric
Tim, thats why I keep the 24 coupe hid in the big barn till my TT is finished.
