Hand crank build.
Petrah Phyre
First Name: Sean
Last Name: Pownall
* REQUIRED* Type and Year of Model Ts owned: 1926 Speedster
Hand crank build.
Post by Petrah Phyre » Thu Dec 09, 2021 10:45 pm
My speedster has the front axle mounted in front of the radiator. This necessitates a longer crank. I fabed one up, but have a couple of questions.
How far back from the ratchet end is the spring pin hole drilled?
Is there just a pin to hold the spring in place, or a pin and washer?
I can't seem to find any pictures.
Re: Hand crank build.
Post by Steve Jelf » Thu Dec 09, 2021 11:36 pm
There is no pin or washer to hold the spring.
The outer end of the spring has a little bend that sticks into the tiny hole in the crank handle. The hole is 5½" out from the back end of the crank.
JohnM
Last Name: Michaelree
Board Member Since: 2010
Post by JohnM » Thu Dec 09, 2021 11:54 pm
Al it has to do is pull the crank away from a moveing crankshaft.
Petrah Phyre
First Name: Sean
Last Name: Pownall
Post by Petrah Phyre » Fri Dec 10, 2021 12:10 am
Thank you for the pictures. This clear things up well.
