plastic coil box paint
NY John T
Last Name: Killelea
Post by NY John T » Fri Dec 10, 2021 2:56 pm
Hi All,
Just wondering about the new coil box rebuild kit with plastic wood. Does anybody have any good/bad experience with painting the outside black? I noted that carbon in paint would cause problems. Does anybody have a recommendation for what paint would work? What about acrylic?
Thanks,
John
Re: plastic coil box paint
Post by Steve Jelf » Fri Dec 10, 2021 3:56 pm
If the car is pre-26 I wouldn't bother. The firewall hides it. For 26-27, how about putting on a layer of wood grained contact vinyl before you install the hardware?
NY John T
Last Name: Killelea
Post by NY John T » Fri Dec 10, 2021 6:06 pm
It's a 26.
Professor Fate
Last Name: S
* REQUIRED* Type and Year of Model Ts owned: '23 and '26
Post by Professor Fate » Fri Dec 10, 2021 6:41 pm
I used the rebuild kit from Lang's with great success on my '26. The plastic is black and you really can't tell it's not wood until you touch it.
Went together quickly <1hr. Well worth the $70. The old wood I removed was cracked badly..... an ignition problem in the making.
________________
**FATE**
