Muncie transmission manual
Reno Speedster
Topic author - Posts: 636
- First Name: Morgan
- Last Name: Blanchard
I have a nice Muncie transmission that I got from a friend who passed away a few years back. Is in good shape and came complete with the special U joints and the cutdown torque tube and drive shaft. As you can see in the photo, it’s going in my 26 speedster build. What I don’t have is a manual for this transmission. I see that there used to be a reprinted manual available for them. If someone has a copy of this (digital or paper) they could send me I would appreciate it.
Also, does this take an odd bearing between the input and output shafts like the warford?
Steve Hughes
- Last Name: Hughes
- * REQUIRED* Type and Year of Model Ts owned: 1926 Touring 1921 Centerdoor
Re: Muncie transmission manual
I am in just the same situation as you. I just got a car that requires assembly and it has a Muncie transmission. If someone does come up with a manual for this transmission I would really like a copy too.
tmodeldriver
- Last Name: Hester
- * REQUIRED* Type and Year of Model Ts owned: 26 touring, 27 touring, 22 TT
Me too. I'm willing to pay someone to make a copy of his Muncie manual. Bob
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
The Muncie bolts directly to the back of the T hogshead/pan. There are no adalpter plate etc as used on the iron case Warford. You stated you had the special ujoints- only the front uses a special ujoint with the female end shorter than a ford u-jont. The rear uses a stock Ford u-joint, but there is a female-female square hole coupler that you need for the rear u-joint. This coupler adapts the Ford u-joint male end to the male output shaft on the Muncie.
StevenS
- First Name: Steven
- Last Name: Sebaugh
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring, 1924 TT Truck
To All:
Morgan, Steve, Robert, and anybody else.
I have the MUNCIE installation manual/parts list, and some more information too. I will need to make a "pdf" file of it to send (Monday/Tuesday next week.). Please send me an email and I will reply with the information. The Muncie gear box was sold under different names. This instruction says "Wards Gear Shifter" sold by Montgomery Ward, but the parts list that comes with it says "The Muncie Gear Shifter"
1924 Model T Touring
1924 Model TT Truck
1928 Graham-Paige model 619
1930 Model A Phaeton
1924 Model TT Truck
- First Name: craig
- Last Name: leach
Hi Morgan,
I have built several Muncies the short U/joint in the front and the adaptor in the rear are the holy grail of Muncies. Check the U/joint for wear they have a small wear surface in the square so many are worn out. The Female square adaptor on the rear can be made from a 10-3-22X Spicer yoke cut down to size.
As for the pocket bearing I have seen drawings with a roller bearing in the pocket but have never found one. Every one I have worked on had bronze bushings in them even in the counter shaft. The input & output bearings can be replaced with sealed units that will cut down on oil leaks. I have always been able to find everything I needed at the local bearing house. They have a threaded hole on the tail shaft that works well for a rear support ( I highly recommed one and of coarse Aux. brakes )
- First Name: craig
- Last Name: leach
Pics of Muncie adapters
- Attachments
- IMG_1284.JPG (6.69 KiB) Viewed 3933 times
- IMG_1283.JPG (7.95 KiB) Viewed 3933 times
Steve Hughes
- Last Name: Hughes
StevenS. Thanks for the offer to scan and send the manual. I will send you a PM with my email address. Craig: I don’t understand all of the adapter pictures that you show. I have the long round adapter with the square hole and the universal joint with the short end. What are the others for?
Reno Speedster
Craig Leach wrote: ↑Sun Dec 19, 2021 1:45 pmHi Morgan,
Thanks Craig. My u joint looks quite good. No play in it. I also have the adapter. Mine came with a home made support, but it does not seem to fit, at least I can’t figure out how.
Steven. I will send you my email address. I really appreciate you sending the information you have.
- First Name: craig
- Last Name: leach
Hi Steve, Sorry I didn't explain the two duplicate pics are of the output adapter I made & the yoke I made it from. The next two are of the input adapter I made to replace the U/joint for the input. ( its not cut to length yet ) and some of the impact sockets that can be used to make them. They are 13/16" square bud wheel inner lugnut impact sockets ( the sockets are used to tighten wheels on big rigs to 500 lb.ft. )to fit the Muncie and the square is 7/8" cold rolled steel milled to fit in the socket & the output of a model T. This makes a input much like a Warford. I have more Muncies that U/joints. The first Muncie I purchased had one on the input made out of cut up T U/joints. Crude but appeared to have been used for quite awhile.
The front flange assembly has to be bored out to accept the socket but that should be no issue if using the sealed bearings. These are not original ideas of mine they have been past on to me from others. With testimonials that they work. Past performance is in no way a garantee of future results. All the parts used are capable handling more torque than a T can produce.
Steve Hughes
- Last Name: Hughes
Thanks, Craig. Makes sense now. Fortunately I have a good condition U-joint and the rear adapter so don't need to make anything up. Well, maybe a rear support. Have to figure that one out.
StevenS
Here is the Muncie Gear Shift Manual. download is below, a PDF file
1924 Model TT Truck
1924 Model TT Truck
tmodeldriver
- Last Name: Hester
Hi, Steven. The file printed out very nicely for me. Thank you so much for providing it.
I hope you and your loved ones have a very Merry Christmas. Bob
I did my radius rods like shown when I installed my Warford. That allowed me to get things setup before riveting the two sections together.
Thanks for posting that link.
- First Name: craig
- Last Name: leach
StevenS, Thanks for the Muncie info. You are a gentleman and a scholar and your generosity is only exceded by your good looks and fine personality. Merry Christmas.
