and a Merry Christmas to all!
Today I put my Lizzy on four support frames (I got yesterday) to prevent flattened tires. So I tried to rotate the wheels by hands to test the bearings.
Front wheels run absolutely freely, a little push with a finger tip and they turn multiple times.
Back wheels are much different, they turn much harder.
Of course, the handbrake lever is in middle position, so emergency brakes (should?) be fully released, and gear is in neutral. I also verified that A.C. brakes are fully released, their bands have a little clearance, I can move their bands 1-2 mm sideways. During my first test drives I experienced that emergency brakes are holding properly (no car creeping after cold engine start).
When turning one wheel I can hear a little grinding noise originated in rear brakes. From my opinion it is too much when I need to use more than 4 lbs (2kg) of force on outer wheel diameter to make the wheel turn. It turns really stiff compared to a modern car. From my opinion, it could be the emergency brake system, but I don't know if this is normal or not.
I need to say, I currently have no Rear Wheel Puller, so I cannot pull the wheels to look into brake-drums. This puller (and the hub-cap wrench) are the next tools I will buy, but you know, nobody should buy tools around Christmas or his birthday... This I learned when I bought a car jack for my Lizzy, now I have two.
How easily should rear wheels turn in my case?
As all force applied to one wheel directly goes through the differential to the other wheel, wheels should turn very freely, any stickiness of cold oil inside the High Speed Clutch should not matter at all.
Please let me know.
