26 hogs head
Topic author - Posts: 365
- First Name: Rich
- Last Name: Jesteadt
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1913 Touring project w. "A" crank shaft
26 hogs head
Has any one modified an regular block to mate to a 26 hogs head using the mounting ears?
Re: 26 hogs head
I haven't, and I'd speculate that the earlier blocks would not have enough iron in that area to do it.
- Last Name: Catlin
- * REQUIRED* Type and Year of Model Ts owned: 1923 depot hack
Re: 26 hogs head
Took the holes in the 26 hogshead and threaded a plug-in.Then taped the plug to accept a 5/16 bolt so I could still use the two arms that connect to the frame rails.
- First Name: Ken
- Last Name: Buhler
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster 1927 Coupe
- Board Member Since: 2012
Re: 26 hogs head
That is not stopping the pan twist which causes broken crankshafts.
Work honestly
Stay true to your word
Get the job done right
- Last Name: House
Re: 26 hogs head
Ken is right. Just get those 2 accessory L brackets that fit under the crankcase with 4 bolt holes each that stabilizes the tranny cover, pan and block. I’m at the Dr. office now but someone will list the correct nomenclature.
Re: 26 hogs head
Oil Pan SupportsGeorge House wrote: ↑Tue Jan 04, 2022 11:12 amKen is right. Just get those 2 accessory L brackets that fit under the crankcase with 4 bolt holes each that stabilizes the tranny cover, pan and block. I’m at the Dr. office now but someone will list the correct nomenclature.
L's https://www.modeltford.com/item/3118-19.aspx
Belly https://www.modeltford.com/item/3114SPT.aspx
