CANADIAN front license bracket, 26-7
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Fri Mar 29, 2019 6:37 pm
So in a moment of silly I have embarked on another part reproduction project!!
This bracket bolts to the front fender arm and can fit either side. Typically it was on the drivers side. I’m currently obtaining costs and as is typical the more copies I make, the lower the unit cost will be. If you are interested, please respond.
The next project will be making new Canadian brake lights. That will be a REALLY entertaining project!!
Last Name: Humble
Board Member Since: 2006
Re: CANADIAN front license bracket, 26-7
Post by Humblej » Fri Mar 29, 2019 7:36 pm
Interested
Pops
First Name: David
Last Name: Houston
* REQUIRED* Type and Year of Model Ts owned: 13,14,19,21,&etc
Post by Pops » Fri Mar 29, 2019 10:38 pm
Hello Les: Put me down as insterested in the "Front License Bracket" POPS
Alan Long
First Name: Alan
Last Name: Long
Post by Alan Long » Fri Mar 29, 2019 11:20 pm
Hi Les,
I too would be interested in the design / location. I have been seeking an alternative
location for my Number Plate for ages. Currently it sits behind the crank handle and is almost non visible
as I have front bumper bars too. Maybe the Geelong models were different again and I should look at the
original car here in Perth. I’m about to locate it in a wooden board in the centre of the bumper bars.
Regards Alan
Ken Buhler
First Name: Ken
Last Name: Buhler
Board Member Since: 2012
Post by Ken Buhler » Fri Mar 29, 2019 11:53 pm
Hello Les, Unfortunately we missed contact last summer on our camping trip tour through Calgary. Thank you for first of all for your ability to design and make these parts that improve our cars, and more importantly, your interest and willingness to create them. I am building a car like yours and would certainly be honored to have one of those brackets, and a floating transmission shaft, and probably anything else you make for this car. Again my gratitude.
Work honestly
Stay true to your word
Get the job done right
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sat Mar 30, 2019 12:51 pm
Ken
Thank you for the kind words.
So I will probably make 10 copies. Hopefully in a couple of weeks
Last Name: Humble
Post by Humblej » Sat Mar 30, 2019 1:18 pm
Can you post a picture of it?
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sat Mar 30, 2019 8:39 pm
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sat Mar 30, 2019 8:41 pm
Well adding the pictures is easier than on the old forum!!!
Alan Long
First Name: Alan
Last Name: Long
Post by Alan Long » Sat Mar 30, 2019 9:29 pm
With the Bracket being located there certainly encourages hand cranking from the bottom up only!
Alan
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sat Mar 30, 2019 9:49 pm
Alan
The edge of the plate is about at the edge of the radiator core. So clear of the crank
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sat Mar 30, 2019 9:50 pm
And of course well behind it too
Eck
First Name: William
Last Name: Sheppard
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster pickup
Post by Eck » Sat Mar 30, 2019 10:43 pm
I also would like one for my 26. Please add me for one on your list Eck
ChrisB
First Name: Chris
Last Name: Brancaccio
Post by ChrisB » Sat Mar 30, 2019 11:01 pm
Put me down for 2 please Les
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
Glen McConachie
First Name: Glen
Last Name: McConachie
* REQUIRED* Type and Year of Model Ts owned: A few 1926 - 27 Tudors and coupes
Post by Glen McConachie » Sun Mar 31, 2019 4:01 am
Hi Les
I am also interested in at least 6 when it happens.
Curious to know more about the possible brake light project also
Many thanks
Glen McConachie
Dunedin
New Zealand
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sun Mar 31, 2019 1:36 pm
So now it looks like at least 20 pieces.
I’ll be getting the parts laser cut and I’m pursuing finding a local supplier with a spot welder to put the parts together
Tiger Tim
Last Name: Eckensviller
* REQUIRED* Type and Year of Model Ts owned: 1926 cut-off touring
Post by Tiger Tim » Sun Mar 31, 2019 11:27 pm
Am I too late to put my name in for one? My current front plate mounting is destroying my radiator, may as well do it right.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sun Mar 31, 2019 11:37 pm
No problem
John Warren
Last Name: Warren
Post by John Warren » Mon Apr 01, 2019 8:25 am
Hi Les, Put me down for one also. On Canadian cars, should the hole in front fender support already be there? Thanks jw
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Apr 01, 2019 12:37 pm
Yes it uses the existing front upper bolt
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Apr 16, 2019 3:38 pm
These should be ready tomorrow. If you are interested please contact me
Thank you
Last Name: Humble
Post by Humblej » Tue Apr 16, 2019 4:31 pm
Les, how much do they cost, how much for shipping, and how do you want to get payment.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Apr 16, 2019 8:24 pm
I think that it will probably work out to $30.00 with shipping. I have not had a chance to confirm this though, just a guess!!
kmatt
First Name: Kevin
Last Name: Matthiesen
* REQUIRED* Type and Year of Model Ts owned: 1926 Coupe, 1921 speedster, 1925 TT, 1916 Exp
Post by kmatt » Wed Apr 17, 2019 2:56 am
Les, I would like a bracket, I sent you a email via this system with my email contact. If you didn't get it; kmatt at netptc dot net
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Wed Apr 17, 2019 6:26 pm
[ima
e][/image]
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Wed Apr 17, 2019 6:27 pm
So here they are, all done!!
Eck
First Name: William
Last Name: Sheppard
Post by Eck » Wed Apr 17, 2019 9:58 pm
Looks great !! Thank you. This is the first time I have got on the forem in a week or so and not sure how I did it. Just let me know where and amount to send and it will be on your way. Did not find personal message , just your mail message. Keep getting Torgan message and stops my progress. Thanks again for your hard work. Eck
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Thu Apr 18, 2019 1:31 pm
Checked shipping cost and yes $30.00 US total price to the USA.
I will accept PayPal, or check or cash.
My mailing address is 100-182028 174 Ave West, Foothills AB T1S 2B8, Canada
Tiger Tim
Post by Tiger Tim » Thu Apr 18, 2019 11:17 pm
Do you have a total cost for us Canucks, Les?
Eck
First Name: William
Last Name: Sheppard
Post by Eck » Fri Apr 19, 2019 7:21 pm
check is in the mail Thanks Eck
John Warren
Last Name: Warren
Post by John Warren » Sun Apr 21, 2019 12:01 pm
check is in the mail, Thanks jw
John Warren
Last Name: Warren
Post by John Warren » Sat May 11, 2019 11:12 pm
Hi Les, Just wanted to thank you for the WOW new license bracket. Thanks again. jw
Barth_Tool_Co
First Name: Jason
Last Name: Alvord
* REQUIRED* Type and Year of Model Ts owned: '26 Touring
Post by Barth_Tool_Co » Sat May 11, 2019 11:26 pm
I got mine and it looks great! Thanks for investing the time, $$$, and energy into the project.
... and my number is Beechwood 4-5789
1926 Touring - "Corrina"
