On track !
Rich Bingham
Topic author - Posts: 1942
- First Name: Rich
- Last Name: Bingham
On track !
How about this ? No information with the photo, looks like foreign military.
"Get a horse !"
Bryant
- First Name: Bryant
- Last Name: Shafer
Re: On track !
I love that thing! I have a few different shots of it saved. The front tag is turned around backwards and they painted words on it. Says US ARMY on the top but I can’t quite make out the bottom half. Looks like ORDDEPT
not sure
Bryant
- Last Name: Shafer
Re: On track !
office of research and development department?
Robert Kiefaber
- First Name: Bob
- Last Name: Kiefaber
- * REQUIRED* Type and Year of Model Ts owned: 1906 model F, 1907 model R, 1915 centerdoor sedan, 1921 centerdoor sedan
Re: On track !
Looks like general Pershing standing there.
Burger in Spokane
- First Name: Brent
- Last Name: Burger
- Board Member Since: 2014
Re: On track !
The bridge looks a dead ringer to the Monroe St. Bridge in Spokane.
Joe Voller
- First Name: Joe
- Last Name: Voller
- * REQUIRED* Type and Year of Model Ts owned: 1924 pickup 1922 centerdoor
Re: On track !
Never could figure out how they made it turn Any ideas?
Kerry
- Last Name: van Ekeren
Re: On track !
Ordnance department at Rock Creek Park Washington, Sept 1921.
Bryant
- Last Name: Shafer
Re: On track !
I believe they just turn the wheel and the tracks just cater to one side with the wheel. They are called “chase tracks” they keep them selfs centered with the wheel because they are flexible. Basically drives the same just more traction. Also when it’s running the front wheels don’t touch the ground. Just like a tank.
Bryant
- Last Name: Shafer
Re: On track !
Thou not a T but these examples might help visualize how the track moves. Kinda like a snakes belly. Just follows the head.sorry Iam a fool for things with tracks
130nav
- First Name: Matt
- Last Name: C
- * REQUIRED* Type and Year of Model Ts owned: 26 Touring
Re: On track !
According to that article it was steered with differential braking on either side of the drive axle. I would think if you turned the front wheels with those tracks on you’d make the inside track loose and stretch the outside track.
Bryant
- Last Name: Shafer
Re: On track !
Your right! I did see that. Makes me wonder if the brakes added are only to aid the inside track during turning? You can see it still has its steering tie rod in it. I wouldn’t think it would take much to make it turn. this picture you can see the large break drum. Looks like it has a guiding/drive apparatus strapped to the rear wheel. I used the motorcycle examples because that’s how they turn by flexing the track. But I guess I could be wrong.
Bryant
- Last Name: Shafer
Re: On track !
found this drawing. Pretty neat.
Bryant
- Last Name: Shafer
Re: On track !
this one shows the flexibility they had. One article started the steering wheel was kept so you could take the tracks off and drive it normal. Can’t seem to find how the brakes are applied.
Les Schubert
- First Name: Les
- Last Name: Schubert
Re: On track !
Interesting that on the 2 wheel version they are using solid rubber tires.
