I need to find floor cover pictured
Caswell
First Name: Dean
Last Name: Brevit
Post by Caswell » Sun Jan 16, 2022 1:18 pm
Anyone know a supplier of cover pictured below ?
Last Name: Patrick
Re: I need to find floor cover pictured
Post by jiminbartow » Sun Jan 16, 2022 1:41 pm
I can’t tell from the picture, the size and shape of the projections. Check McMaster Carr (www.McMaster.com). Search “rubber mats” then choose projections. There might be a mat design close to what you need. Jim Patrick
John iaccino
Last Name: Iaccino
* REQUIRED* Type and Year of Model Ts owned: 1911 Roadster, Open Runnabout
Post by John iaccino » Sun Jan 16, 2022 2:37 pm
Check with Wittmer Coach in New Holland, PA. I found black pyramid rubber matting there. It is sold by the yard. I then painted it with flexible white paing.
John iaccino
Last Name: Iaccino
Check with Wittmer Coach in New Holland, PA. I found black pyramid rubber matting there. It is sold by the yard. I then painted it with flexible white paint.
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Sun Jan 16, 2022 3:57 pm
Restoration Supply Co. has white vinyl 1/4” pyramid 48” wide, $29.00 per foot.
Post by Rich Eagle » Sun Jan 16, 2022 4:26 pm
Page 33 of their online catalog. They have Vinyl, Rubber and aluminum.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Sun Jan 16, 2022 5:25 pm
The late Ken Jones restored a 1911 roadster and it has pyramid aluminum floor covering over the rear floorboards.
If I recall correctly, the original pyramid aluminum was in rough shape but he was able to find a suitable replacement which is probably the same pyramid aluminum that is posted in the catalog above.
Larry
Last Name: Gresh
Post by Larry » Sun Jan 16, 2022 5:49 pm
How much do you need?
If you can’t find any,
I probably have a roll.
Caswell
First Name: Dean
Last Name: Brevit
Post by Caswell » Mon Jan 17, 2022 12:26 am
Thanks everyone, I think I found some at a lower price (could be junk) 36" wide $5.00 per linear foot, I ordered 8' . If it's not correct I will take you up on your offer Larry. Again, Thank All.
Last Name: Hjortnaes
Post by DHort » Thu Feb 10, 2022 12:35 pm
That is looking really nice Dean. Will you be painting or staining the floorboards before you put the mats down? What do you plan to use to hold the mats down so they dont curl up in the corners? Hope you can bring your car to Nebraska some day for the Speedster Union.
Caswell
First Name: Dean
Last Name: Brevit
Post by Caswell » Thu Feb 10, 2022 2:11 pm
That is looking really nice Dean. Will you be painting or staining the floorboards before you put the mats down? What do you plan to use to hold the mats down so they don't curl up in the corners? Hope you can bring your car to Nebraska some day for the Speedster Union.
Thanks again, I will paint the floor with black paint, I have brushed on some West System epoxy already, will sand and paint soon. The hard part is dry fitting everything then taking it all apart for paint, I'm going to use 3M spray adhesive for vinyl to hold down covering, if it lifts at the corners I'll put a small tack in.
