13 touring
Model T Mark
Last Name: Eyre
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring 1914 Touring and Roadster 1915 Touring 1926 Roadster
13 touring
Post by Model T Mark » Mon Jan 17, 2022 6:28 pm
New to me 13 touring
Last Name: House
Re: 13 touring
Post by George House » Mon Jan 17, 2022 7:17 pm
Congratulations on the touring. Original upholstery too !! Keep us informed on the degree of restoration you’ll take it to.
Re: 13 touring
Post by John kuehn » Mon Jan 17, 2022 7:29 pm
Nice find! Looks to be mostly original. It does have demountable rims and front add on Hassler shocks. It’s up to you of course but if it were mine I’d leave the demountable rims. That was an improvement. Good luck.
Re: 13 touring
Post by Rich Eagle » Mon Jan 17, 2022 7:33 pm
That looks fantastic from that photo. I'd love to see more.
Regardless of what you do with it have fun and enjoy it.
Thanks for mentioning and showing it.
Hap_Tucker
First Name: Hap
Last Name: Tucker
Re: 13 touring
Post by Hap_Tucker » Mon Jan 17, 2022 7:47 pm
Mark,
Congratulations! Looks like a great car!
You probably already know that the earlier 1913 bodies had a manufacture's fix provided to the customer at no cost. Note the Beaudett body did not appear to need this fix as often and the same is true for cars produced after Mar 6, 1913. But if you have an early 1913 and it does not have the reinforcement brackets, you may want to consider installing them or some type of reinforcement before you drive it a lot?
Ref: https://www.mtfca.com/encyclo/doc13.htm
JAN 28 1913 Acc. 575, Letter 395, Ford Archives
T-5637 Body Reinforcing Bracket Bolt. "Four required, Touring Car, 1913."
T-5453 Body Reinforcing Bracket. New Drawing. "Two required, Touring Car, 1913."
T-5638. Sketch showing location of Body Reinforcing Bracket. "We have made this sketch for the purpose of showing customers who are having trouble with the touring car bodies how the trouble can be overcome. The material has been ordered and we will be able to supply same in the near future. For your information will state that the construction of the body has been improved upon and undoubtedly will not need this reinforcement as soon at the change can be brought about. We will therefore order only enough material of the above parts as shown on sketch to take care of the bodies which have already been built."
FEB 12 1913 (Letter from Ford to the Chicago branch)
"We have decided to place an extra body bracket just beneath the tonneau door hinge of the Touring Car body, extending from the frame of the body sill as you will observe from blue print enclosed. We have entered order to send you one hundred pair of these brackets and we want you to put them on every car now in stock. It is also our object to supply larger dealers with a quantity of these brackets so that they can install them before the cars are put out on the road next spring. The purpose of this bracket is to stiffen the body sill and prevent too much play in the door when the top is down, also binding in the door when the top straps are drawn up too tightly."
Installation instructions followed with hints on how to add or subtract shim washers in order to align the doors.
MAR 4 1913 Letter, Ford to the Cincinnati branch
"In attaching the Touring Car body reinforcing brackets, be sure they are fitted 1/8" to 3/16" from the top of the frame so that when the bolts are put in it will pull the sill down. Unless the sill is sprung down 1/8" or so when the bracket is attached but little benefit will be derived by the reinforcement. All bodies coming through from now on will be fitted with heavier sills so that attachment of extra brackets will be unnecessary."
JUN 12, 1913 Letter from Ford to all branches
"In order that all our branches may clearly understand the handling of complaints on present touring car bodies we submit the following:
"It is expected that you will furnish all Dealers with body sill reinforcements, wood reinforcements for the rear seat frame and also rear corner brackets as shown in the attached blue print. To make a satisfactory and permanent repair all of this material should be put in. We have found that the sills break most frequently within a few inches of the rear end and in such cases the rear corner brackets will serve to bind the sills together. The wood reinforcements in the rear seat will relieve the rear ends of the sills from all strain, consequently there is no necessity of replacing the sills on account of the wood splitting at the end. In applying the steel stamping underneath the tonneau door you will find it necessary to chisel out the wood at the lower rear corner on all Beaudett bodies and perhaps shim up other makes of bodies where the bracket spreads out at the rear.
"As this body trouble is going to be more or less general perhaps you had better employ one or two good body men to do this work. We believe this will be better that to leave the work to the ordinary shop mechanics to handle. As the season advances you will probably have a great deal of this work to do and you might as well prepare for it now."
JUL 14, 1913 Acc. 575, Letter 434, Ford Archives
Noted that 1913 Touring bodies were made by Herbert, Fisher, Wilson, and Beaudett. Apparently the Beaudett bodies differed in construction from the others. Beaudett bodies with a filler block on the rear door hinge posts apparently did not need the steel reinforcing pieces.
NOV 24, 1913 Letter from Ford to the Denver branch)
"Kindly give us by return mail your present inventory of the following:
T-5668 reinforcement, right
T-5669 reinforcement, left
T-5675 rear seat frame reinforcement
T-5678 rear corner bracket."
These are the 1913 touring body reinforcement parts.
Again, congratulations on your "New" addition!
Respectfully submitted,
Hap l9l5 cut off
Model T Mark
Last Name: Eyre
Re: 13 touring
Post by Model T Mark » Mon Jan 17, 2022 7:59 pm
It has 5 lug demountable wood fellow accessory wheels on in with a spare rim which I’ll keep on it. It doesn’t have the reinforcement on it wish it did. It has a later block in it but I have a spare. The passenger front fender is a 15. Has gnarled spark and throttle rods and a large patent plate dad and I have chased it since the early 80s and when the barn started falling down we knew the time was near and the owner called us Friday night set a realistic price on it and we picked it up yesterday. I plan on making it core and leaving it alone.
Model T Mark
Last Name: Eyre
Re: 13 touring
Post by Model T Mark » Mon Jan 17, 2022 8:02 pm
Correct that is not core.
Re: 13 touring
Post by speedytinc » Mon Jan 17, 2022 8:21 pm
Firestone wheels? The later fender is neat. If it has/or looks like its been on most of its life, I would keep it. That will rattle the purists. It may have been there over 100 years. Wouldnt you like to know the story?
Model T Mark
Last Name: Eyre
Re: 13 touring
Post by Model T Mark » Mon Jan 17, 2022 8:28 pm
I know it’s from Virginia probably sold new there from what the previous own said. The last time it was run was sometime in the early seventies. I wish I would have taken a picture of the barn we took it out of. There was a bunch of 55 chevys parked in front of it. All of which had flat tires and broken frames . It was 2 degrees when we started loading it and it slipped my mind to take a picture of it. I walked into a frame from a 68 camero and cut my jeans and shin all up. It was a down town setting. Huge mess.
Re: 13 touring
Post by John kuehn » Mon Jan 17, 2022 8:43 pm
Neat story about finding it where you did which proves there are T’s out there to be found. At least it was in a covered bldg and not ruined by the elements. T’s don’t last long on the outside.
Last Name: Humble
Board Member Since: 2006
Re: 13 touring
Post by Humblej » Mon Jan 17, 2022 10:00 pm
Mark, this story is getting better and better. Downtown where? In Michigan?
Model T Mark
Last Name: Eyre
Re: 13 touring
Post by Model T Mark » Tue Jan 18, 2022 5:30 am
North West side of Battle Creek.
Last Name: Humble
Re: 13 touring
Post by Humblej » Tue Jan 18, 2022 7:50 am
Go back and get some pictures of the barn and junk. This could be a good article for the Vintage Ford.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: 13 touring
Post by ThreePedalTapDancer » Tue Jan 18, 2022 8:56 am
In this chaotic, fast paced, ever changing world, there remains a constant. Great old patina Ts are still out there, sitting in garages and barns, waiting to remind us, that some things never change.
