Today I removed the top tank and filled it with water over the kitchen sink. I turned on the valve, but I didn't see any water dripping out of the center tube on the bottom of the tank. What should the drip rate be?
I have heard that the reproduction tanks are intentionally made not to function to avoid liability. If mine is a repro, how can I make it function?
----------------------- UPDATE ---------------------------
Update - Never mind, I just wasn't patient enough. After 30 seconds or so, water started dripping out the center tube at a rate of one drop every 5 seconds or so.
I bought some carbide, along with some lamp oil for the side and tail lamps and plan to test them with some friends some evening when the weather is warm enough.
