Rings unavailable
DJPeterson
First Name: Dale
Last Name: Peterson
* REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1916 Roadster, 1925 Roadster PU, 1926 Canadian Fordor, 1927 Speedster
Rings unavailable
Post by DJPeterson » Wed Jan 19, 2022 1:01 am
Ready to put the engine back together on the 15 Touring. Had to be bored to 20 over. Pulled out the new rings and found out they were std, not 20. This is for domed HC pistons, and when I contacted Lang's and Snyders, found out they are on back order. Now what to do? Any one have a set of 20 over Hastings HC rings to trade for std?
greenacres36
First Name: Brian
Last Name: Williams
* REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1915 Runabout
Re: Rings unavailable
Post by greenacres36 » Wed Jan 19, 2022 2:52 am
I don’t know if this is a solution or not but it is something I had to do. I had to go onto the Hastings website and search around for rings that was the right thickness and diameter. The difference is I have Ford Y block pistons. Then I ordered from Summit Racing. I have no idea if this is a solution that may be something you can look into.
Brian
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Wed Jan 19, 2022 8:06 am
Egge Machine appears to have them.
Hank
Post by Mark Gregush » Wed Jan 19, 2022 10:15 am
Call Chaffin's.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Wed Jan 19, 2022 11:27 am
Another option is to buy even bigger ones and then carefully file the ends to get the correct end clearance. I have done this once in the past. Works fine!
First Name: craig
Last Name: leach
Post by Craig Leach » Wed Jan 19, 2022 12:38 pm
Dale,
Try your local engine biulders. Best as I recall 265 Cu.In. chevy is 3.75 bore and the ring grooves in HC are the same. If you can pick up a set of .020 rings?? you will have to buy them for 8 cyl. so you will have spares. Double check I could be wrong.
Post by Mark Gregush » Wed Jan 19, 2022 1:06 pm
"This is for domed HC pistons" The rings would be different from the stock aluminum pistons as shown in the catalogs.
BobShirleyAtlantaTx
First Name: Bob
Last Name: Shirley
Post by BobShirleyAtlantaTx » Wed Jan 19, 2022 2:01 pm
.030 and file to proper ring gap?
Post by Wayne Sheldon » Wed Jan 19, 2022 2:29 pm
Be careful with this!
I had a situation where I needed to do that, and it turned out the one size larger rings I had were slightly thicker in depth than the proper oversize. Got the engine running, but before it could warm up, the heat expanded the pistons just enough that the thickness of the rings caused the pistons to seize. Allow to cool for twenty minutes and I could crank it again. Only to seize again after half a minute.
They had plenty of gap after I ground them, so they were not gap seizing.
I am sure some rings are different in that dimension.
First Name: craig
Last Name: leach
Post by Craig Leach » Wed Jan 19, 2022 6:49 pm
Dale,
Mark could be correct. Rockauto has 265 rings Hastings #2M5685 rings in .020 they are 5/64 compression & 3/16 oil. Double check.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Thu Jan 20, 2022 3:40 am
"Dale,
Craig."
Pretty sure that ring set has a MOLY coated top ring and you will most likely not be happy with those in a T engine. Hastings does make a an iron top ring set for a 265 Chevy that would work fine if your pistons use a 5/64, 5/64, 3/16 ring setup.
The iron set is probably a Hastings 5658.
FATMAN
First Name: ROBERT
Last Name: BERGSTADT
Post by FATMAN » Thu Jan 20, 2022 11:55 am
We have some sizes in stock, Bob
Philip
First Name: Philip
Last Name: Thompson
* REQUIRED* Type and Year of Model Ts owned: 1924 touring
Post by Philip » Thu Jan 20, 2022 12:56 pm
otto gas engine company says they can supply rings from 5\9 thru 86 inches call him he knows rings. philip
Philip
First Name: Philip
Last Name: Thompson
that is 5\8 thru 86 inches
DJPeterson
First Name: Dale
Last Name: Peterson
Post by DJPeterson » Thu Jan 20, 2022 6:53 pm
Success, finally able to get the rings from Snyder's! :D
First Name: craig
Last Name: leach
Post by Craig Leach » Fri Jan 21, 2022 1:11 am
Dale.
Great to hear. Dan that is a possibility and I would not run moly rings in a bore that is not new. It's getting to where we have to work with what we can get rather than what we wan't. And a set of moly rings for a V8 will have 8 cast iron compression rings as a last resort. I'm finding some parts hard to find for my 1980's vehicles. Some day we will have to look to car guys in Cuba for advice!
