https://www.amazon.com/gp/product/B0849 ... UTF8&psc=1
https://www.amazon.com/gp/product/B07DS ... UTF8&psc=1
I don't think anyone is necessarily suggesting doing this on a regular basis, unless problems have arisen, and then I suppose the screw plug makes an easy access. But for any properly restored NH, it's a must.speedytinc wrote: ↑Fri Jan 21, 2022 12:37 pmDoes anyone really ever need to reopen & clean out the idle passages after the carbs initial restoration? Looks like wasted effort.
Is this an extreme example of OCD?
Is that what you've done?Steve Hughes wrote: ↑Sun Jan 23, 2022 6:36 pmWhy not just mix up a bit of JB weld. Press a little in the hole and strike off the top and let cure. Seals it up but is easy to drill out in the future if needed.
Cool! Thanks!
