Another cool accessory
Topic author - Posts: 1697
- First Name: ROBERT
- Last Name: BERGSTADT
Check this out, never seen one in all my years
inspection plate for transmission cover to allow you to oil the bands
looks like Evers Sauvace
Chicago Il
anyone ever tried one of these,Bob
Chicago Il
- Last Name: Andreasen
- * REQUIRED* Type and Year of Model Ts owned: 0...building from parts
Re: Another cool accessory
That is really interesting............but it looks like one of those solutions looking for a problem. With all that oil sloshing around inside, why would you need to "oil" the bands?
Still pretty cool though and deserves a display spot on the wall.
- Last Name: Warren
It would be great for start up after a long sit. First start I always add one quart to the transmission on top of the bands.
Actually that accessory isn’t to ‘add oil’, but rather for adding a heavy grease-like compound.
The waxy thick compound squirted out the two nozzles to spread it on the linings, to retard glazing and help reduce chatter.
Missing is the twist T-handle and the tube nozzels, the handle is placed after packing the reservoir, the cap keeps out stuff when the T-handle is removed, plus originally a screen was inside to prevent anything but the compound from getting in the hogshead.
- First Name: Stan
- Last Name: Howe
Thought I'd seen em all!! That's pretty cool!
I wonder if 2 different companies made this the only name on this is Evers Sauvace
Bob
Bob
- First Name: Don
- Last Name: Demio
- * REQUIRED* Type and Year of Model Ts owned: 1919 T
Dan,
Once again you pull a "rabbit out of the hat." You are amazing and your willingness to share information is commendable. I don't need to learn another thing today.
My best to Julia too,
Dom
Dom
Dom
No wonder with me, as an elephant just have good visual memory
This accessory has been shown before on the forum!
Phttp://www.mtfca.com/discus/messages/3487/9171 ... 1543371699
Bob
If you open link on patent you can see Mr Evers was the patent idea guy, as assigned the patent to Evers-Savage Co
Seems two styles, early with knurled twist knob, later with T handle. These ads in 1921-1923 so guess not too many, the one ad states to just use cup grease, the other more marketing by selling the compound as special Red Cup
Bob
Very cool, thank you, the t handle in not here just a big brass round head screw but does have the tabs for turning it down
Bob
Bob
- First Name: Adam
- Last Name: Doleshal
There is another variation of that accessory that was advertised as using mica grease. I think that is the one Bob has. The injector tubes are missing.
