Violet Ray Lens
				GG Gregory
Topic author - Posts: 326
 - First Name: GG
 - Last Name: Gregory
Violet Ray Lens
I just got a nice set of Violet Ray Lenses for the Roadster.  I know the visor was originally black, gloss or flat ? I’m thinking flat.
dobro1956
 - First Name: Donnie
 - Last Name: Brown
Re: Violet Ray Lens
My original nos pair was close to a satin or semi-gloss. I used  satin rustoleumn on another set I have on my tractor conversion. It is really close looking from the back. I can not tell any difference from the front looking thru the glass.
				GG Gregory
 - First Name: GG
Re: Violet Ray Lens
Thanks, I’ll try satin on them.
Re: Violet Ray Lens
Refurbished a single spare for my pair of Violet Rays.
The originals were a semigloss black, on the inside of the visor . But that black was then second coated with white paint too. Reason is the white backing allows for more illumination from the bulb and reflector. The visor casts the beam down some to prevent light into on coming drivers eyes.
The best way is always the simplest. The attics of the world are cluttered up with complicated failures.     Henry Ford
				GG Gregory
 - First Name: GG
Re: Violet Ray Lens
Thanks Dan!  The white top coat makes sense.
				oliverguy
 - First Name: Bryan
 - Last Name: Grube
 - * REQUIRED* Type and Year of Model Ts owned: none at the moment
Re: Violet Ray Lens
The ones I have have green eyebrows
Re: Violet Ray Lens
The green visor is the Macbeth brand.  The lens is clear, the Violet Ray glass is a blue tint.
				TractorGlenn
 - First Name: Glenn
 - Last Name: Heim
Re: Violet Ray Lens
Dobro1956  What brand of tractor conversion do you have?
