Steering gear casting inquiry
Dropacent
Last Name: Morsher
Post by Dropacent » Fri Jan 28, 2022 1:41 pm
I’m easily confused. I need a steering gear casting for a 1925 fordor or chassis. What casting numbers am I looking for? The confusion is checking the parts books. I believe those numbers are for castings with bushings installed, hence the confusing numbers, Thanks for any help. AND if you have one , I’m looking. Thanks!
Re: Steering gear casting inquiry
Post by DanTreace » Fri Jan 28, 2022 2:12 pm
Tim. If you mean The lower steering bracket. That one is unique to the 26-27 Fordor and Chassis only. Look for factory number on the bracket. T-933. Ford parts list # 3539E.
Post by DanTreace » Fri Jan 28, 2022 2:22 pm
Opps. Missed that you mentioned 1925.
That one will have T-932B casting mark factory number. It fits all body styles pre-26.
Post by RajoRacer » Fri Jan 28, 2022 3:47 pm
I have a bucket of them Tim - forward your mailing info & I'll get one headed your way.
Dropacent
Last Name: Morsher
Post by Dropacent » Fri Jan 28, 2022 4:45 pm
Thanks! Steve, hold on to that bucket, I’ve got one on the way already. AND I printed out that info, very helpful.
Post by RajoRacer » Fri Jan 28, 2022 6:55 pm
You bet - I also have some re-bushed w/new felts too !
