Question on removing tape
FATMAN
First Name: ROBERT
Last Name: BERGSTADT
Post by FATMAN » Wed Feb 16, 2022 2:20 pm
I just got in a super ?? rare item
1926-7 drive plate poss NOS.
The owner said it was but he wrapped the shaft with black electrical tape years ago , I got the outer tape off but the resedue is super thick, tried almost everything even 3 m remover best stuff still no help, been soaking, do not want to bead blast will clog hoses, any ideas? Bob
sweet23
First Name: Darryl
Last Name: Bobzin
Re: Question on removing tape
Post by sweet23 » Wed Feb 16, 2022 2:24 pm
Wrap a rag around it and keep it wet with 3M adhesive remover. I have very good luck with that stuff. Darryl
Post by Norman Kling » Wed Feb 16, 2022 2:26 pm
Have you tried laquer thinner? Or Acetone? You need a very strong solvent to remove it. Should be doable. Maybe paint remover?
Pep C Strebeck
First Name: Joseph
Last Name: M
Post by Pep C Strebeck » Wed Feb 16, 2022 2:32 pm
Agree with Norm, Acetone. Let it soak a little bit to soften it up and then a good sharp blade/scraper to remove the bulk, the rest should just wipe off.
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Wed Feb 16, 2022 2:48 pm
There is always the shade tree fall back (horror) - gasoline....
Last Name: Seth
Post by perry kete » Wed Feb 16, 2022 2:59 pm
WD-40 removes most adhesives. I've used it to remove ceramic tile glue from carpet as well as chewing gum. Takes tape residue off without harming painted surfaces.
Post by TRDxB2 » Wed Feb 16, 2022 3:08 pm
I have used Naphtha to remove price tags off of the boxes of collector toys without any damage. Doesn't seam to harm anything, softens the glue and wipes off. Doesn't stain. NEED good ventilation, fumes will get to you if you hover over them too long.
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Wed Feb 16, 2022 3:28 pm
This chemical is often categorized into one of two categories: aliphatic, or "light," and aromatic, or "heavy." Aliphatic compounds contain more of a chemical compound called paraffin. They are sometimes called paraffinic compounds.One common use of this chemical is as a solvent. Naptha is a very strong and versatile solvent which can be used in hydrocarbon cracking, laundry soaps, organic chemistry, cleaning fluids, and many other applications. The product also is used to make varnish and to fuel camping cook stoves and lamps, as well as in the processing of fuels such as gasoline and kerosene.
Post by John kuehn » Wed Feb 16, 2022 4:58 pm
Yes that terrible stuff called gasoline would probably do it. Lacquer thinner would do it. Both are highly flammable but they work.
cslandry
First Name: Chris
Last Name: Landry
* REQUIRED* Type and Year of Model Ts owned: 1915 Speedster, 1926 Touring, 1923 Depot Hack project
Post by cslandry » Wed Feb 16, 2022 6:48 pm
3M Adhesive Remover is good stuff
Altair
First Name: David
Last Name: Menzies
Board Member Since: 2012
Post by Altair » Wed Feb 16, 2022 9:20 pm
What about a propane torch and burn it off.
Last Name: Patrick
Post by jiminbartow » Wed Feb 16, 2022 9:28 pm
Like Frank said, if you have a collectible box or a valuable book that someone in the past has taped, do not try and pull the tape off. The tape will rip off the graphics that make the box, book or document, valuable. Instead, saturated the item with Naptha and keep it wet. You can soak one side of the box or document at a time and after the Naptha has soaked through to reach the adhesive on the underside of the tape, gently pull the tape off, leaving the graphics in perfect condition. Have patience. Do not try and hurry it. Any adhesive that is left can be gently wiped off until it is no longer sticky. I once purchased a 1934 Buck Rogers “Rocket Pistol” with the very rare original box. When I received it, the box was covered in tape. I used the Naptha method to remove the tape until the box was in pristine, toy museum condition and sold the box and gun for $1,200.00. Jim Patrick
