I Was Surprised To See This
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Sun Feb 20, 2022 9:15 pm
I was surprised to see this much felt packing in the two pack nuts. It was very difficult to remove. This may not be unusual, but thought I would show it anyway.
I also show a piece of new felt packing that was in a gasket kit I purchased. I am not going to use it but instead will purchase a neoprene seal.
I was curious about how the felt piece would fit onto the gas line and then into the nut. I tried to put it onto the gas line, but the hole in the felt is way too small for it to fit. The felt is dense enough that I could not enlarge the hole. Any comments on how these felt gaskets are installed?
Re: I Was Surprised To See This
Post by RajoRacer » Sun Feb 20, 2022 9:30 pm
Slide the nut on the line, completely soak the felt in motor oil, slide it on the line, bring the nut to the felt then using a blunt piece of steel or wood, stuff the felt into the nut enough to get a few threads started "straight" then tighten it up !
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Sun Feb 20, 2022 9:31 pm
Run a proper sized Phillips screwdriver into the packing hole to enlarge it a bit then manhandle the felt onto the gas line after the fitting goes on first. Then use a tiny regular screwdriver to force the packing into the fitting.
Steve Hughes
Last Name: Hughes
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring 1921 Centerdoor
Post by Steve Hughes » Sun Feb 20, 2022 11:19 pm
Throw the felt in the trash can and use a piece of neoprene gas line instead of the felt.
Post by Steve Jelf » Mon Feb 21, 2022 12:04 am
...use a piece of neoprene gas line...
