T-3456 Park Pawl.
Topic author - Posts: 310
- Last Name: Hand
- * REQUIRED* Type and Year of Model Ts owned: 1912 open express, 1920 touring, 1926 tudor-lisenced and insured, 1921tt project 1922 fendered chassis, 192x tt dootle bug 192xengine w/winch projects
T-3456 Park Pawl.
Parking Pawl striped it's tooth this week, went to check Snyder's Model T because they will not let you order something not in Inventory. So are the T-3456 Pawls the Latest T part made from "unobtainium"? I checked Sunday afternoon, do not believe other parts suppliers will confirm availability online as you Order George
- Last Name: Juhl
Re: T-3456 Park Pawl.
It takes a telephone call to verify if something is available. Some vendors have parts "in the back" that they don't list in their catalogs or online.
You may already know but Lang’s has lots of good used or NOS parts. They advertise to call and ask. Or they use to.
If you have a good eye and can weld you can build up a worn pawl end. Also Chaffins may have one.
Bobs use to have a supply of older NOS small parts but he may have sold most of his parts that he had.
- First Name: Joseph
- Last Name: M
If not available through the regular vendors, here is one from an "alternate" vendor (Ebay). I have no connection to the seller, I only remember seeing it listed.
https://www.ebay.com/itm/154780953684?h ... SwLvFh1M1P
- First Name: Robert
- Last Name: Jablonski
The handbrake quadrant usually wears out faster than the handbrake pawl.
Yes the quadrant will wear faster if you drag the handle back and hear the “ratcheting sound” of the pawl clicking on the quadrant teeth. Pushing on the thumb lever on the handle will slow the wear.
You can look at T frames that have the quadrant really worn and others not so much. The drivers of years ago had different handbrake techniques I guess!
- First Name: Nick
- Last Name: Miller
- * REQUIRED* Type and Year of Model Ts owned: 1926 touring
Our 1926 touring needed the quadrant and pawl replaced, i thought. I bought both and went to a workshop for a couple of our clubs here in Florida, and they thought it was easier to bolt the quadrant to the frame after grinding off the rivets (only 2 on the 26) and welding up the worn pawl (as we did not have the rivet to attach it to the lever). The weld was ground down to match the teeth on the quadrant. The quadrant was bolted to the frame and works great. It was required to take the pipe across under the car to each side break rod to be removed and reinstalled. Also. time to oil the pivot point of the pipe thru the frame, that had never been oiled i think. Good for another 90 years. Thank you. Steve, Charley and Phil.
- Last Name: Wrenn
I got a new pawl this week from them plus a quadrant "for future needs".
The part number for t he pawl is T-3458
Not sure who all you tried but S&J or even Birhaven/Texas T/Fun Projects (they may have one, its something they don't make
I think)
9 available, new, on eBay https://www.ebay.com/itm/154780953684?h ... SwLvFh1M1PGeorge Hand wrote: ↑Sun Feb 27, 2022 2:49 pmParking Pawl striped it's tooth this week, went to check Snyder's Model T because they will not let you order something not in Inventory. So are the T-3456 Pawls the Latest T part made from "unobtainium"? I checked Sunday afternoon, do not believe other parts suppliers will confirm availability online as you Order George
They are selling off the old inventory from the Ford Barn. there will more listings coming
Frank
I've mulled your astute observation some and can only shake my head at the fact that it is a sad situation when a vendor is more likely to have something in stock if they do NOT make it themself.
When I heard the other day that Berg radiators were no longer available, my first thought was "B-------- must have bought them out".
Where's the thumb lever ¿?.???John kuehn wrote: ↑Sun Feb 27, 2022 5:20 pmYes the quadrant will wear faster if you drag the handle back and hear the “ratcheting sound” of the pawl clicking on the quadrant teeth. Pushing on the thumb lever on the handle will slow the wear.
Give a call to your vendors today Monday since most of those are closed on SundayGeorge Hand wrote: ↑Sun Feb 27, 2022 2:49 pmParking Pawl striped it's tooth this week, went to check Snyder's Model T because they will not let you order something not in Inventory. So are the T-3456 Pawls the Latest T part made from "unobtainium"? I checked Sunday afternoon, do not believe other parts suppliers will confirm availability online as you Order George
Before the vendors had RHD panels, I rebuilt originals with weld and oil hardened them.
I'ts not hard to do.
- First Name: Jack
- Last Name: Tarlinton
- * REQUIRED* Type and Year of Model Ts owned: 1927 Cut off
Hi Allan,
Do you happen to have any spare right hand drive pawls? Mine is not much good and I'd like to replace it.
Best regards
Jack
