Disc drum question
RGould1910
Last Name: Gould
Disc drum question
Post by RGould1910 » Mon Apr 01, 2019 2:47 pm
Is the disc drum used with the 3 washers different that the one used with the flange bushing? I am working on a 27 and need to replace the disc drum. I have about half a dozen spares and they all look the same, even the one that came out of a 1912 transmission.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Disc drum question
Post by Dan McEachern » Mon Apr 01, 2019 7:32 pm
Yes there is a difference. it is not really well documented, but the difference is between the thrust surface and the centerline of the lock screw. I'll check at the shop, but I recall the one without the Ford script is the early version. RV Anderson originally posted this info 3-4 years ago if I recall, quoting a brief entry in a service bulletin from round 1921.
Post by Mark Gregush » Mon Apr 01, 2019 8:57 pm
From what I picked up; that the early one has several holes around it, the later style has just two. (the holes you would use for pulling it)
RGould1910
Last Name: Gould
Post by RGould1910 » Mon Apr 01, 2019 10:23 pm
Thanks for the info gentlemen.
Post by RajoRacer » Tue Apr 02, 2019 10:06 am
There are actually 6 holes around the circumference and a spiral oil groove machined/cast into the bottom where it rides against the "top hat" bushing - I dig one out & post a photo.
Dan McEachern
First Name: DAN
Post by Dan McEachern » Thu Apr 04, 2019 12:00 am
To clarify this for everyone- I went back and looked up my printed copy of the forum posting that Trent Boggess did on this several years ago.
The clutch hub that was made for use with the top had brake drum bushing can be identified by there being NO ford script on the hub at all or the Ford script will be located on the brake drum (front) side of the clutch hub.
Later clutch hubs made for use with the 3 steel washers have the Ford script on the side opposite the brake drum (rear) or set screw side.
Steve- FYI: I have both styles that only have 1 pair of puller holes 180 degrees apart, so I don't believe the # of puller holes will completely identify the early or late hub.
Trent noted that this info came from a 1920 Ford service bulletin.
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Thu Apr 04, 2019 2:34 am
This one came out of a 1914 transmission. It has no Ford script anywhere, I thought there was a DB but there’s not. The flywheel was marked Dodge Bros. I guess is why I thought that.
Dan McEachern
First Name: DAN
Post by Dan McEachern » Thu Apr 04, 2019 12:14 pm
Correction- "top had brake drum bushing" should have been "top HAT brake drum bushing". sorry for any confusion.
