Ford Called it "The Universal Car" this Photo is Proof of that Statement
David Greenlees
- Last Name: Greenlees
- * REQUIRED* Type and Year of Model Ts owned: 1913 Model T racing car, 1924 Model T Depot Hack with original York #803 body.
- First Name: Dennis
- Last Name: Seth
Re: Ford Called it "The Universal Car" this Photo is Proof of that Statement
That's one way to keep kids off your lawn!
I really don’t think he was worried about keeping the brass radiator cleaned and polished!  The roller must have been really geared down to use it.   I have an idea that the rollers could be water filled for the weight.
- Last Name: House
Never seen that Model T use before. Thanks for showing it. Interesting vertical steering w/ chains
Kaiser
- First Name: Leo
- Last Name: van Stirum
No more worries about your spokes collapsing in a turn
Leo van Stirum, Netherlands
				OilyBill
- First Name: William
- Last Name: May
If that transmission is set in low, with the reduction to the rear axle and the chain sprocket reduction, I bet that was a VERY powerful machine.
Obviously, the owner had experience with those big farm threshing engines, with their post steering using chains.
Many (if not most) early road rollers used water drums for the rollers. It made the roller easier to transport, and you could fill it up with a garden hose and it was ready to flatten right then. When you were done, stop it so the plug is at the bottom of the wheel rim, let it all drain out, then load it up to take it to the next job. You could probably move this one on a Model T Flatbed truck with no trouble at all. Whoever built this did a very nice job!
Susanne
- First Name: Susanne
- Last Name: Rohner
Having that car creep when you start it would make it a smashing success...
