Moore transmission drive shaft
Tracer
First Name: Andrew
Last Name: Webb
* REQUIRED* Type and Year of Model Ts owned: 1915 Towncar 1921 Centerdoor 1913 Racer 1927 Fordor 1927 Tudor 1926 Tudor 1927 Coupe 1926 Ute1926 Tourer 1915 Town Car
Post by Tracer » Sun Mar 06, 2022 8:57 pm
Hi All
Is the Moore transmission drive shaft a cut down ford one or did it come with the gearbox from Moore ?
Picture for reference
Cheers
Andrew
First Name: Keith
Last Name: Townsend
Re: Moore transmission drive shaft
Post by KWTownsend » Sun Mar 06, 2022 9:53 pm
A cut down Ford driveshaft is used with a Moore transmission.
Post by Allan » Mon Mar 07, 2022 4:26 am
Andrew, mine was a whole unit when found, with the shaft already made to fit, so i can't answer your question. Do you have the change lever/ It comes with a quadrant which allows the lever to be set in neutral, allowing the Moore equiped car to be flat towed. If you have a Moore, it pays to learn to change, both up and down, while still on an up slope. You learn to drive defensively to be safe. If you go to a 3:1 diff ratio, let me know and I will run you through how to fit it all together.
