temperature probe in sherman head???
Loftbed
Topic author - Posts: 251
- First Name: Rod
- Last Name: Letcher
Am I wrong in assuming that this port is for a Temp Probe? (black arrow)
Rod
Rod
- Attachments
- SHERMAN.png (303.76 KiB) Viewed 2921 times
1965 Shelby Cobra (Factory Five repo)
1957 Ford Thunderbird
1941 Ford PU
John iaccino
- Last Name: Iaccino
Re: temperature probe in sherman head???
I have a Sherman head on one of my Fords. I was told it was a port for removing sand from the mold. I don't know much about this process, but that is what I was told.
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
yes you can install a temp gauge sensor in that hole. Some heads have them and some don't.
Loftbed
- First Name: Rod
Thanks Dan.Dan McEachern wrote: ↑Fri Mar 11, 2022 3:23 pmyes you can install a temp gauge sensor in that hole. Some heads have them and some don't.
1941 Ford PU
Loftbed
- First Name: Rod
I had a brand new Bosch mechanical temp gauge still in the packaging (who knows how long I've had that laying around). Installed it in the head and am running a 190* temp consistently after about a 15 minute drive, seems about right to me.
Just saying
Rod
Just saying
Rod
1941 Ford PU
kmatt2
- Last Name: Matthiesen
Back in the 1920’s many flat head T racers ran a extra water pipe out of that location in the head in order to improve cooling circulation at the back cylinders. The extra pipe would tie into a modified outlet at the front of the head. If you want a to use a mechanical gauge you can tap the T block rear core plug hole as another option.
kmatt2
The temp probe out of that location in top of the head, as shown, is just fine also.
Joe Bell
- First Name: Joe
- Last Name: Bell
When pouring a casting you have to hold the core some how from moving when being poured, some use the core others use chablits that melt into the pour. Years ago when I made some cast iron heads, I held the core from the side and so there was a soft plug in the side of the head.
babychadwick
- First Name: Chad
- Last Name: Azevedo
Not a bad idea to put a zinc in.
