Have all of the equipment to babbitt and bore T mains and rods and and other early engines and have been doing it for over 40 years. However, instead of using babbitt for this application, I'm considering using Onan connecting rod insert bearings in one or two original 1920s T racing engines of my own. One is a Fronty racing engine with a DO Fronty crankshaft and an S-R head, and the other is a sleeved down 3-7/16" bore 122 CI Green Engineering racing engine; both have period racing cranks.
When the time becomes available to finish the chassis and car rebuilding process, I would like to use one or both of these engines in pre-war vintage races with the VSCCA, which we have raced with for years. The handy part of using these bearings would be the center main bearing which wears faster that the other two would be changeable in the car.
If anyone has done this conversion, would like to know how it worked out in use, how did they hold up, and any issues you may have encountered.
UPDATED: Through an old timer at my engine parts supplier - New England Engine, I've found out which Onan engine used these bearings. They are 1" wide and available in 1.626" std. size and -.010" and -.020" under. As you can see in the photos, three sets of these bearings are used for the rear main and the center and front main use two sets spaced apart and that space is used for the oil groove.
The thrust surfaces on the rear main are machined out of 660 bearing bronze and attached with machine screws.
Photos by Fred Hoss in the Vintage Ford Volume 23 Number 5
