Hot air pipe, air intake pre-heater
Last Name: Patrick
Post by jiminbartow » Tue Mar 22, 2022 9:30 pm
This hot air pipe was on my 1926 Model T coupe which was equipped with a Holley NH carburetor when I bought it in 1970. What years does this hot air pipe fit? Did it fit other carburetors besides the Holley NH? Thank you. Jim Patrick
Re: Hot air pipe, air intake pre-heater
Post by Mark Gregush » Tue Mar 22, 2022 10:58 pm
See Dan's post below.
Post by speedytinc » Wed Mar 23, 2022 8:52 am
I am not seeing the pronounced flattened area to clear the late adjuster. This one looks like pre 25.
John Codman
Last Name: Codman
Post by John Codman » Wed Mar 23, 2022 10:26 am
That pipe appears to be identical to the one on my '27 which is also equipped with an NH.
Post by speedytinc » Thu Mar 24, 2022 8:55 am
25-27 heat pipe on the right.
late heat pipes.
late heat pipes.
Side view
Side view
Note the face relief on the right to clear the mixture/choke rod for 25-27 carburated engines. Both fit on the late, beefier style exhaust manifold.
Post by DanTreace » Thu Mar 24, 2022 10:22 am
Correct John, and here is comparisons to the earlier heat stove pipes.
The late pipe is recessed at the upper side to clear the new combo choke and carb adj. rod with the universal joint.
That new assembly was shown in the July 1925 Service Bulletin.
