Lifter guides
RGould1910
Last Name: Gould
Lifter guides
Post by RGould1910 » Thu Apr 07, 2022 2:26 pm
When the lifter guides are bored to the max and there is still too much play, what do you use to bring the bores back to standard or at least the first OS?
I've heard of using a flange bushing with the flange at the bottom pressed into a circle milled out under the guide. Should be an easier fix with just a thin steel bushing.
What do folks do?
Re: Lifter guides
Post by speedytinc » Thu Apr 07, 2022 2:35 pm
What do folks do?
The lifter bores get bored out for replacement lifter guides presses in, just like valve guides.
Press fit is enough. Not familiar with special flanged bushings & counter bores. Guides should be cast iron, not steel.
pete eastwood
First Name: Pete
Last Name: Eastwood
Re: Lifter guides
Post by pete eastwood » Thu Apr 07, 2022 5:37 pm
you could hard chrome the lifters oversize
Re: Lifter guides
Post by speedytinc » Thu Apr 07, 2022 5:47 pm
You could bore to .500 & use .292/312 y block lifters. Thread them for an adjusting screw. One of my T's is running them now.
First Name: Henry
Last Name: Lee
Re: Lifter guides
Post by Henry K. Lee » Thu Apr 07, 2022 5:54 pm
There is plenty of side access if you wish to use a set screw for piece of mind. Just Sayin'
Hank
Les Schubert
First Name: Les
Last Name: Schubert
Re: Lifter guides
Post by Les Schubert » Thu Apr 07, 2022 7:36 pm
Years ago I put model A lifters into a T block. Worked fine.
I am putting the Y block ones into a engine soon.
TrentB
First Name: Trent
Last Name: Boggess
Re: Lifter guides
Post by TrentB » Fri Apr 08, 2022 6:45 pm
NOS Ford replacement T push rod guides look like this:
Respectfully submitted,
Trent Boggess
RGould1910
Last Name: Gould
Re: Lifter guides
Post by RGould1910 » Sat Apr 09, 2022 10:46 am
Great info and photos. Thanks.
Trent do you know if the lifter guides in the block are part of the block casting or are they separate pieces thar can be pressed out. If not then the block must be bored to accept the replacement guides, correct?
Much of my experience is with 09, 10 early 11 blocks with the removable guides.
Last Name: Hatch
Re: Lifter guides
Post by Dan Hatch » Sat Apr 09, 2022 11:59 am
Part of casting, must be bored out.
Any machine shop that can install valve guides can install lifter guides. Should even have a modern guide to do the job. Dan
FATMAN
First Name: ROBERT
Last Name: BERGSTADT
Re: Lifter guides
Post by FATMAN » Sat Apr 09, 2022 12:05 pm
I have some nos guides,Bob
TrentB
First Name: Trent
Last Name: Boggess
Re: Lifter guides
Post by TrentB » Sat Apr 09, 2022 1:55 pm
1909 to early 1911 open valve engines used replaceable brass push rod guides.
Trent Boggess
