Steering Gear Ball Arm
Topic author - Posts: 504
- First Name: Daniel
- Last Name: Snell
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
- Board Member Since: 2014
I have a pitman arm ball that measures .965 by .992 is that too out of round to be used successfully? if so, what are the recommendations, go with a repro? Thanks
Re: Steering Gear Ball Arm
Thats enough wear to fix or replace. If not you will have a loose situation straight &/or binding in a turn. The repops seem ok. They are cheap enough. I have installed a few & have not heard of any failures. I personally prefer to weld them back up & ground the ball round. The ball should be 1.000". One can compensate for some drag link wear making the ball a bit oversize.SurveyKing wrote: ↑Mon Apr 11, 2022 7:06 pmI have a pitman arm ball that measures .965 by .992 is that too out of round to be used successfully? if so, what are the recommendations, go with a repro? Thanks
Bill Barth used to sell reconditioned pitman arms with new balls on the end. Don't know if he still does. He used to sell them at Chickasha.
- First Name: Darryl
- Last Name: Bobzin
- * REQUIRED* Type and Year of Model Ts owned: 2, '25 T Runabouts, '14 Touring
You dont say what year your car is. The reproductions are of the last design steering gear ball arm. Darryl
- Last Name: Snell
It is a 1925 RPU. Parts listings show part number 3547 for that year.
- Last Name: Stroud
- Board Member Since: 2011
I built mine up with bronze and ground to a close fit with a hand grinder and finished with emery cloth using a good cap for fit. Worked great and didn't take very long either. JMHO Dave
1925 mostly original coupe.
Easiest fix for a 25 model is a new repop. Early slim ones are well worth fixing.
- Last Name: Snell
Anyone have a contact for Bill Barth whom Larry Smith indicated used to rebuild the pitman arm ball? Thsnks
All I could find of the gentleman .
I save early slim ones in the following way.
Set some calipers to 1/2" and grind two flats on opposite sides of the worn ball, using the calipers as your guide.
Do the same on adjacent side to make a 1/2" square.
Then knock the four corners off and hand file the rest into 1/2" round.
I use a 1/2" die to tap a fine thread onto the created stub.
Chuck a new straight shank replacement tie rod ball from the vendors in a lathe, counterbore the ball and tap a 1/2" fine thread into the hole.
Use the straight stub and some lock-on pliers to thread the new ball onto the pitman arm, with loctite if desired.
Cut off the stub and make a good weld to lock the ball to the arm. File to finish.
The neck on the arm is still smaller than the stub created for the new threaded on ball, so there is no weakening of the arm. The weld does not create enough heat to worry the metalurgy/strength either. And, if you ever have to replace the ball again, it is not hard to do.
Hope this helps,
Hope this helps,
- First Name: Tyler
- Last Name: Prondzinski
I personally wouldn't cut the old ball off and weld a new one on. If that were to fail then you have no steering and are most likely dead. I'd rather spend the time welding and filing the ball.
Sent you an email with contact info.SurveyKing wrote: ↑Tue Apr 19, 2022 10:42 pmAnyone have a contact for Bill Barth whom Larry Smith indicated used to rebuild the pitman arm ball? Thsnks
There is also a Bill Barth Jr in the same Town, Berthoud CO, so they must know one another (pop 10,000+) contacting one could get to the other.Jerry VanOoteghem wrote: ↑Wed Apr 20, 2022 12:34 pmThat's Bill's picture, but I'm pretty certain he's not the piano tuning Bill...
Yes, I'm sure they all get together on weekends.TRDxB2 wrote: ↑Wed Apr 20, 2022 3:52 pmThere is also a Bill Barth Jr in the same Town, Berthoud CO, so they must know one another (pop 10,000+) contacting one could get to the other.Jerry VanOoteghem wrote: ↑Wed Apr 20, 2022 12:34 pmThat's Bill's picture, but I'm pretty certain he's not the piano tuning Bill...
- First Name: Adrian
- Last Name: Whiteman
Sounds fearsome lot of filing and grinding - but I have done it too, just takes patience and time. (not bad for an accountant eitherI personally prefer to weld them back up & ground the ball round. The ball should be 1.000".
