1914 Model T Side Lights
DontKnowMuch
Last Name: Sanford
* REQUIRED* Type and Year of Model Ts owned: 14 Touring, 26 Roadster, 27 Roadster
Post by DontKnowMuch » Tue May 03, 2022 1:08 pm
I have a 1914 touring and I'm trying to put together a set of side lights and tail lights for the touring. I have looked at the Encyclopedia and It shows black and white pictures of the lights. It shows that Brown 100 and 115 and the Victor 2 as appropriate for that year.
I have seen various lights for sale with clear beveled glass, red round lens about 3" in diameter, small flat red lens about 2" in diameter, and small red jewels. I believe that the Brown 115 tail lights may have had a blue lens as well. The Victor side lights may have two styles of mounting brackets - the bar mount with set screw and "butterfly" wing brackets that screw into the firewall. i mention Brown and Victor since i have some of these but most need repairs.
I would appreciate help in identifying which combination of square, clear glass and colored lens/jewels are appropriate for 1914. If this has already been discussed in a previous post, a link to this discussion would be appreciated.
Thanks for the help
Last Name: Tannehill
Board Member Since: 2002
Re: 1914 Model T Side Lights
Post by JTT3 » Tue May 03, 2022 4:19 pm
14 had a transition in lamp style, earlier had the jewel as did the 13 style, later the jewel was replaced with a blank steel panel.
Last Name: House
Post by George House » Tue May 03, 2022 5:28 pm
Don’t overlook Corcoran ‘14 cowl lamps and the ever popular E&J ‘14 cowl lamps 😁🇺🇦 And the lamps you see with the round 3” lens is a tail lamp. Inboard of that lens you’ll see a clear glass lens meant to “shine” on the license plate. Opposite the clear lens will be a blue/green lens next to the LR fender.
rickd
First Name: Rick
Last Name: Duquette
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring, 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
Post by rickd » Wed May 04, 2022 9:53 am
James, these are the sidelights and taillight on my 14 Touring. The Jno Brown sidelights are Model 110. You mention Model 100 in your post, that model is for a 12. The taillight is a Jno Brown Model 115. Blue lens to the driver side, red lens to the rear, clear lens pointed at the license plate. These lights have all been restored but retain the original configuration of black and brass. Hope this helps, let me know if you have any more questions.
Russ T Fender
First Name: Val
Last Name: Soupios
Post by Russ T Fender » Wed May 04, 2022 10:59 am
I don't think anyone mentioned this but I believe that some of the later side lamps in '14 had integral mounting brackets.
Post by JTT3 » Wed May 04, 2022 11:34 am
Yes that’s true, late 14.
Last Name: House
Post by George House » Wed May 04, 2022 1:53 pm
And 1913 Victor # 1 had cast iron mounting brackets. I know because I sold a pair to Dale Kemmerer.
Post by JTT3 » Wed May 04, 2022 4:52 pm
That’s right George, even though not numbered those were the first and I really like the embossing of the Ford on the early Victors. I have them on my 13 with the unusual tail light & Victor # 1 headlights with the steel smoke bonnet. They are just very well made and look great.
DontKnowMuch
Last Name: Sanford
Post by DontKnowMuch » Wed May 04, 2022 5:07 pm
Thanks for all of the responses.
How do you remove dents from the brass tops?
What is the secret to cleaning the reflectors on the inside of these lights?
Any help is appreciated.
Last Name: House
Post by George House » Wed May 04, 2022 6:17 pm
James, fashion a concave hard wood dowel of approximate size and shape of the dent. Find a sand box and remove the lamp font. Turn the lamp upside down in the sand box and insert the dowel through the bottom of the lamp up through the chimney onto the dented part. Lightly tap dowel prn. 🇺🇦...John; I’m in witness protection and you’ve blown my cover. Now I haveta move 😞😜
Post by JTT3 » Wed May 04, 2022 9:09 pm
George a correction has mysteriously appeared.
DontKnowMuch
Last Name: Sanford
Post by DontKnowMuch » Fri May 13, 2022 10:31 am
George, I tried your method but the dent can’t be reached by a straight dowel. It is farther to the outside of the top so I need to find something with a slight curve. Also, the brass tops have an inner liner so how do you get past that to reach the dent in the brass top?
