Rear Axle/driveline play
Topic author - Posts: 88
- First Name: Quinn
- Last Name: Golden
Hello
I recently brought my 1926 Runabout out of storage to get it started. When I would attempt to engage the starter the car would try to drag forward. So I jacked it up and put stands under the rear axle, reset the air fuel mixture, choke, crank it over twice, turn on the ignition and it fired right up.
However while I had it up in the air, I was doing some checking, I lowered one rear wheel to the ground and then rotated the other rear wheel in my hands.
How much should I be able to turn the other wheel forward and backward with the brake off and one wheel resting on the ground?
Re: Rear Axle/driveline play
I don't know a figure for "how much", but I can tell you there's normally a lot more play than you would guess there should be. It's an accumulation of all the clearances in your, ring & pinion, universal joint and differential.QGolden wrote: ↑Sun May 15, 2022 6:56 amHello
- Last Name: van Ekeren
With all parts in spec in the drive line and measuring at a wheel nut on a demountable, one inch rock is all that you should be getting.
- First Name: Art
- Last Name: Mirtes
There should be a difference between the transmission brake set and not set.
The slack in the system is contributed to by the play in the axle gears in the differential and the three spider gears, then the crown wheel and pinion mesh, then the play in the universal joint and then within the transmission components. Kerry's 1" would be the absolute best with everything in original spec. I would expect 3-4" in any setup that had been used for any length of time. When you make a stop in a T, often the car will rock at the end of the stop. This can happen because of the brake being on the transmission. The rock is all the slack in the driveline, compounded by the torque on the drivehaft and axles exerted by the braking force. Slack is normal.
- First Name: Chris
- Last Name: Barker
While the rear wheel is aloft, check the AXIAL float as well. It needs to be minimal.
- First Name: Quinn
- Last Name: Golden
Not sure, I will Jack it back up and check, I did not measure it. I’d say 3 inches, but will check again as soon as I can.
- First Name: Quinn
- Last Name: Golden
Thanks, presume you mean lateral play (in and out) I will check again, I only checked one side and it was not discernible.Chris Barker wrote: ↑Mon May 16, 2022 11:05 amWhile the rear wheel is aloft, check the AXIAL float as well. It needs to be minimal.
