Question re repro pedal cams
RGould1910
Last Name: Gould
Post by RGould1910 » Wed Apr 10, 2019 9:07 pm
Thinking about puchasing new cams for the brake and reverse pedals. Any concerns I should be aware of? Ie quality of the pieces, how they fit with original pedals with the usual amount of wear, or other conerns.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Question re repro pedal cams
Post by Dan McEachern » Thu Apr 11, 2019 12:05 am
Gotta believe there are still good originals out there. Have you contacted Langs or bob Bergstadt?
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Thu Apr 11, 2019 6:05 am
I just built mine up on the TT with a bit of weld with a Mig, didn't grind them to fit very much, just touched them up. Worked great for me. Dave
1925 mostly original coupe.
Post by DanTreace » Thu Apr 11, 2019 8:53 am
IMO the reproduction pedal cams are just fine, sure beat old used worn cams, now if you CAN find NOS pedal cams...great :P But don't hold your breath!
What works good is a pedal in good shape when coupled to a repro pedal cam, action is restored about the best you can do.
Worn cam compared to reproduction.
Worn cam on a original pedal as removed.
Reproduction cam on same pedal, good fit and function.
RGould1910
Last Name: Gould
Post by RGould1910 » Thu Apr 11, 2019 9:53 am
Thank you for the helpful and informative advice, suggestions and illustrations!!! :P
