Camshaft lift question.
NoelChico
Topic author - Posts: 296
- First Name: Noel
- Last Name: Chicoine
If I have a .250 lift camshaft, does it lift the valves .250 or do you subtract the 10-12 thousandths of lifter clearance and you only get .238-.240 lift?
Re: Camshaft lift question.
you lose the clearance. A .250 lift is the actual measured difference between the max & min dimensions of a cam lobe.
NoelChico
- First Name: Noel
thank you, John
