Winfield Carbs
ModelTWoods
First Name: Terry
Last Name: Woods
Winfield Carbs
Post by ModelTWoods » Fri Jun 03, 2022 10:42 am
I know Winfield carbs were made in different sizes. What are the largest and smallest Winfield carbs? What is the largest size that can be used om a T motor, while still retaining drivability for street use, if the motor has a .280 or .290 lift cam and a Model A exhaust manifold? Is a Winfield even recommended for street driving?
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Winfield Carbs
Post by Kevin Pharis » Fri Jun 03, 2022 10:55 am
Check out this article on the evolution of the Winfield carbs
https://www.nwvs.org/Technical/2104WinfieldHV.pdf
The Winfield catalog shows a S-A-U for a performance T or stock A application, I’m about to put a S-AA-U on the A crank motor in my ‘15 touring
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Winfield Carbs
Post by Kevin Pharis » Fri Jun 03, 2022 3:30 pm
Here is a 4V I ran on my ol ‘27 roadster. It ran kinda funky at first, but after building a new barrel and boring the housing to seal up the vacuum leaks at idle, and figuring out that the idle screw and air bleeds were installed in the wrong screw holes, it ran like a top! Basically stock T engine
SR-C-U on my noticeably modified T speedster motor... for now!
S-B-D on my dads Fronty powered touring
And the S-AA-U going on my somewhat modified T touring
kelly mt
Last Name: Kelly
Re: Winfield Carbs
Post by kelly mt » Sat Jun 04, 2022 11:47 am
I ran a Winfield SR on my Tudor and it ran good. Had to pull it when the diaphragm went bad. looking for parts.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Winfield Carbs
Post by Kevin Pharis » Sat Jun 04, 2022 12:26 pm
Check with Brauns Automotive down in SoCal. He started making his own accelerator pump diaphragms after having issues with leaking gas thru the center rivet
kelly mt
Last Name: Kelly
Re: Winfield Carbs
Post by kelly mt » Sat Jun 04, 2022 1:40 pm
Thanks Kevin.
