Planting Model T seeds
Ed Fuller
First Name: Ed
Last Name: Fuller
Board Member Since: 2012
Post by Ed Fuller » Mon Jun 06, 2022 6:13 pm
I had a couple extra T blocks that weren’t being used. I wondered if I planted some seeds in the cylinders in the early spring that maybe a new Model T might sprout. All I ended up with are these dang flowers! Must have used the wrong fertilizer I guess. At least they help make the front of my shop look a little nicer and I can’t be accused of leaving junk lying around since they are now serving as planters!
Re: Planting Model T seeds
Post by Rich Eagle » Mon Jun 06, 2022 6:27 pm
Nice! Some more good photos of the old Ford Plant.
RVA23T
Last Name: C
Post by RVA23T » Mon Jun 06, 2022 7:15 pm
Probably needs more iron in the fertilizer and less water.
sweet23
First Name: Darryl
Last Name: Bobzin
Post by sweet23 » Mon Jun 06, 2022 7:17 pm
They have to be "watered" with Marvel Mystery Oil for a new T to grow in !
Post by Scott_Conger » Mon Jun 06, 2022 8:57 pm
what I wouldn't give for a couple good blocks within 200 miles of me...*sigh* :(
Ed Fuller
First Name: Ed
Last Name: Fuller
Post by Ed Fuller » Mon Jun 06, 2022 9:43 pm
Scott,
Don’t worry, if these two blocks were in your backyard they wouldn’t do you any good. The area around the valve chamber is shaped really odd. There is no way to get a valve cover to go on or bolt down. Really strange.
Post by Scott_Conger » Mon Jun 06, 2022 9:57 pm
Ed
I assumed there was a fatal reason they were doing double duty...just musing out loud regarding where some of the better stuff ends up. Really wish I had the ability to attend some of the swaps that I read about :)
NoelChico
First Name: Noel
Last Name: Chicoine
Post by NoelChico » Mon Jun 06, 2022 10:11 pm
Scott. I've a daughter in Billings. Perhaps I could throw an old engine in the rig the next time we go to visit. ;)
Post by Scott_Conger » Mon Jun 06, 2022 10:38 pm
And I'd take you up on that offer, too, Noel! That's an easy drive from here!
Last Name: Hjortnaes
Post by DHort » Mon Jun 06, 2022 10:40 pm
Doc
I have a couple blocks I could bring to you in Fond du Lac. Only problem is I do not know if they are still good. Scott can have them for free.
