Need help identifying possible 1909-1911 top strap to radiator clips.
Tony Delbianco
First Name: Tony
Last Name: Delbianco
* REQUIRED* Type and Year of Model Ts owned: 1913 Runabout
Board Member Since: 2022
Post by Tony Delbianco » Thu Jun 09, 2022 5:35 pm
I found these 2 clips (see 4 attached photos) in a coffee can of parts that came with my 1913 runabout.
They look like the clips I've seen that attach the early 1909-1911 top straps down to the radiator bolts hooks, but they are only wide enough to accept about a 9/16"-5/8" wide strap. Seems like the straps would need to be wider. Can anyone confirm that is what these are?...or were these used elsewhere on a model T?
Re: Need help identifying possible 1909-1911 top strap to radiator clips.
Post by RajoRacer » Thu Jun 09, 2022 6:12 pm
Could be later top strap to windshield hinge hooks.
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
Post by Russ_Furstnow » Thu Jun 09, 2022 11:28 pm
These are common snap hooks. The width of the top strap on a 1909 Ford is 7/8". A 1913 Ford used either a 3/4" front top strap or a 7/8" strap, but the hook used for a 1913 Ford was referred to as a "buckle hook." I don't know of any top strap that would be 1/2" wide, which is the width of the strap that would use this type of snap hook. I hope this helps. Russ Furstnow
Tony Delbianco
First Name: Tony
Post by Tony Delbianco » Mon Jun 13, 2022 4:12 pm
Thanks guys for the responses.
So these "Snap Hooks" are too small to have been from a Model T top strap.
Russ...thanks for sharing your knowledge...this is just what I needed to know.
These will go in the non-Model T parts pile, and I can stop wondering about them.
