No high gear
				rlcxz@yahoo.com
- Last Name: Cook
- * REQUIRED* Type and Year of Model Ts owned: 1922 1917
No high gear
Friends T has no high gear.  Low is fine.   Happened all of a sudden.   You think broken spring is the cause???
Re: No high gear
I think a broken clutch spring would cause it. There may be other issues that could cause it.  This question will get more informed attention in the General Discussion Forum. I'd re-post it there.
Re: No high gear
This section is for questions about the site, not car questions. Start by asking on the general forum. You will get a lot more eyes on it.
Re: No high gear
Did you do any adjustments to the parking brake lever or to the screw on the cam of the lever before this happened?  There are two things which could cause the problem.  One would be something wrong with the high speed clutch such as broken spring or disks stuck in the drum.
The other thing would be adjustment of the neutral or something out of alignment which could keep it stuck in neutral when the brake lever is all the way forward. Brake rods adjusted too long could also keep the lever from going all the way forward which would cause it to stay in the neutral position.
Re: No high gear
They last checked in on June 11th and this was their last post.
