MAGNETO POST ISSUE
Topic author - Posts: 150
- First Name: Jim
- Last Name: Wilson
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster Pickup
MAGNETO POST ISSUE
My 26 T magneto quit suddenly. The mag output has been low (15 volts) for some time. I have the shim devise to take up the main bearing slack/mag gap but haven't had the energy to install it. The switch and wiring are good. I removed the post and cleaned/checked it. Still not working. I installed a repro post and have mag again. It appears that the spring loaded center contact may be intermittent. When I compress the contact, I can wiggle the post and see varying resistance readings with my ohm meter. Anybody ever experienced that malady? Is my only option to replace the post? If so, does anyone have one they will part with?
- Last Name: Mills
Re: MAGNETO POST ISSUE
I had a case where I brought a car out of mothballs for a car dealer after 60 years. Exact same situation.
I kept cleaning the post and roughing up the solder blob and shaking my head...
Finally when someone was visiting with me (moxie26) he changed the mag post with a spare...life got good and stayed good!
For what it's worth.....
The magneto contact is one place I prefer to utilize an original Ford part - some of the repros seem to have "issues" !
- First Name: Jim
- Last Name: Wilson
I will advertise for one in the classified section. I only bought the repro part as the quickest way to trouble shoot the problem.
- Last Name: House
Do you have an outside oiler - maybe from the side of the hogshead to the #1 main bearing ? If not, please consider an original magneto post outside oiler. I have one on all my T s. The splash system moves a huge amount of oil to the front of the engine..
- First Name: Jim
- Last Name: Wilson
Yes, I have the outside oiler.
- First Name: Robert
- Last Name: Jablonski
George Mills.... I was wondering where that magneto post went, lol !!! Hey have a great day.
