Radius rod repair.
Topic author - Posts: 941
- First Name: William
- Last Name: Vanderburg
Radius rod repair.
Can you repair a bent radius rod by cold bending or should I heat it!
William L Vanderburg
1922 Center Door Sedan
Re: Radius rod repair.
Cold. cold.
Front & Rear are rolled steel, forming a tappered tube. May have more success with the frontWill_Vanderburg wrote: ↑Tue Jun 21, 2022 2:38 pmCan you repair a bent radius rod by cold bending or should I heat it!
Cold it shall be! Thanks.
