Ruckstell left hand shifter
bobt
Last Name: Thompson
Post by bobt » Wed Jun 22, 2022 5:30 pm
Hello. I'm moving my Ruckstell shift lever to the left with the kit available from the major vendors. Question. Where do the two collars with set screws go? Thanks, bobt
MWalker
Last Name: Walker
Re: Ruckstell left hand shifter
Post by MWalker » Thu Jun 23, 2022 7:45 am
They go against the pillow blocks which hold the shaft to keep it from sliding to either side.
bobt
Last Name: Thompson
Post by bobt » Thu Jun 23, 2022 9:42 am
Pillow blocks? My kit has U bolts.
Post by TRDxB2 » Thu Jun 23, 2022 10:09 am
Good link shows pillow blocks instead of u-bolts
http://www.mtfca.com/discus/messages/50 ... 1447691827
Post by Original Smith » Thu Jun 23, 2022 10:20 am
What a shame!
MWalker
Last Name: Walker
Post by MWalker » Fri Jun 24, 2022 10:16 am
I guess it depends upon which supplier you get the kit from, whether you get pillow blocks or U-bolts. Either way, the principle is the same.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Fri Jun 24, 2022 12:22 pm
I'm surprised there are different manufacturers of this item available from different vendors. I didn't know there were different manufacturers of this item. I thought there was only one kit being made. I guess it pays to check with the vendor before you buy to see what you are getting.
Dropacent
Last Name: Morsher
Post by Dropacent » Fri Jun 24, 2022 12:31 pm
I believe they have always come with Ubolts. I installed one a long time ago and added simple pillow blocks to my install. Including those would add significantly to the price and you’ve heard of T people…………..FWIW , and I’ve been wrong before, but that’s what I remember, t
Ron Mac
First Name: Ron
Last Name: Mc Willie
* REQUIRED* Type and Year of Model Ts owned: 1910 touring, 1911 torpedo, 1913 runabout, 1914 pie wagon, speedsters
Board Member Since: 2010
Post by Ron Mac » Fri Jun 24, 2022 12:34 pm
The older reproductions had simple U bolts. The newer reproductions have pillow blocks. Either one works just fine. I have both on my cars. Remember, this thing barely rotates and it rarely rotates. It just needs to be secured to the frame. Not worth overthinking!!!
Dropacent
Last Name: Morsher
Post by Dropacent » Fri Jun 24, 2022 1:36 pm
Thanks Ron, Lang’s has ubolts pictured, and I wasn’t aware they ever came with bearings. In my simple mind, unless you double nut the U bolt, you will eventually lose a nut. Some of us can’t handle losing too many nuts. Also , a rattle point with bolts. I don’t like to overthink things, but in this aspect, I think pillow blocks are best. I only have an original center shifter now, so Larry can sleep nights, at least as far as I’m concerned. LARRY, RUCKSTELLS AREN’T ORIGINAL ! !
Ron Mac
First Name: Ron
Post by Ron Mac » Fri Jun 24, 2022 1:46 pm
Speaking of losing nuts, a center mounted Ruckstell shifter is a great way to lose or injure a nut if you are not careful entering or exiting your car!!!!!
Another reason to opt for the non-original version!!!!!
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Fri Jun 24, 2022 5:44 pm
Another rattle point?
