Ruckstell left hand shifter
bobt
Topic author - Posts: 304
- Last Name: Thompson
Hello. I'm moving my Ruckstell shift lever to the left with the kit available from the major vendors. Question. Where do the two collars with set screws go? Thanks, bobt
MWalker
- First Name: Mike
- Last Name: Walker
Re: Ruckstell left hand shifter
They go against the pillow blocks which hold the shaft to keep it from sliding to either side.
bobt
Pillow blocks? My kit has U bolts.
Good link shows pillow blocks instead of u-bolts
http://www.mtfca.com/discus/messages/50 ... 1447691827
- Attachments
- 586872.jpg (78.23 KiB) Viewed 3640 times
What a shame!
MWalker
- First Name: Mike
- Last Name: Walker
I guess it depends upon which supplier you get the kit from, whether you get pillow blocks or U-bolts. Either way, the principle is the same.
ModelTWoods
- First Name: Terry
- Last Name: Woods
I'm surprised there are different manufacturers of this item available from different vendors. I didn't know there were different manufacturers of this item. I thought there was only one kit being made. I guess it pays to check with the vendor before you buy to see what you are getting.
Dropacent
- Last Name: Morsher
I believe they have always come with Ubolts. I installed one a long time ago and added simple pillow blocks to my install. Including those would add significantly to the price and you’ve heard of T people…………..FWIW , and I’ve been wrong before, but that’s what I remember, t
Ron Mac
- First Name: Ron
- Last Name: Mc Willie
- * REQUIRED* Type and Year of Model Ts owned: 1910 touring, 1911 torpedo, 1913 runabout, 1914 pie wagon, speedsters
- Board Member Since: 2010
The older reproductions had simple U bolts. The newer reproductions have pillow blocks. Either one works just fine. I have both on my cars. Remember, this thing barely rotates and it rarely rotates. It just needs to be secured to the frame. Not worth overthinking!!!
Dropacent
Thanks Ron, Lang’s has ubolts pictured, and I wasn’t aware they ever came with bearings. In my simple mind, unless you double nut the U bolt, you will eventually lose a nut. Some of us can’t handle losing too many nuts. Also , a rattle point with bolts. I don’t like to overthink things, but in this aspect, I think pillow blocks are best. I only have an original center shifter now, so Larry can sleep nights, at least as far as I’m concerned. LARRY, RUCKSTELLS AREN’T ORIGINAL ! !
Ron Mac
- First Name: Ron
Speaking of losing nuts, a center mounted Ruckstell shifter is a great way to lose or injure a nut if you are not careful entering or exiting your car!!!!!
Another reason to opt for the non-original version!!!!!
- First Name: Adrian
- Last Name: Whiteman
Another rattle point?
