1910 sidelamp brackets
Topic author - Posts: 1128
- Last Name: Gould
Were the sidelamp brackets used in 1910 brass plated or painted black? Here's what I found when I bead blasted paint off the brackets on my 1910. Brass plating over steel. Im wondering if I should shine them up or repaint them. Don't know if these are original. I suspect not. For sure the black paint was applied when the car was restored from parts in the 80s.
- First Name: Ed
- Last Name: Martin
- Last Name: Branigan
- * REQUIRED* Type and Year of Model Ts owned: 1909 two1910,1911, 1913 Tourings
Re: 1910 sidelamp brackets
Who knows what some one had done in the past. One of my 10s were plated and also the starting crank. Hope this helps?
- Last Name: Gould
Thank you fellas!
