How is this mounted?
SteveD
First Name: steven
Last Name: davidson
* REQUIRED* Type and Year of Model Ts owned: 1924 touring
Post by SteveD » Fri Jun 24, 2022 6:39 pm
Looking at the mount on this horn. Why does it have a recessed cup? Is it supposed to sit on a spring?
Re: How is this mounted?
Post by TXGOAT2 » Fri Jun 24, 2022 6:45 pm
Is it an electric horn?
SteveD
First Name: steven
Last Name: davidson
Post by SteveD » Fri Jun 24, 2022 6:47 pm
No, hand klaxon type. Like you mount on the drives "door" of a touring
Post by Jerry VanOoteghem » Fri Jun 24, 2022 6:55 pm
Not everything was made to fit a Model T. Maybe suitable for some other make & model?
Moxie26
Last Name: Jablonski
Post by Moxie26 » Fri Jun 24, 2022 7:05 pm
I agree with Jerry. Been looking for one to fit a bracket that's on a 1922 touring car.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Fri Jun 24, 2022 7:12 pm
You are missing the rest of the bracket assembly.
That particular set-up has an additional bracket that screws into the door sill. Then, you attach the horn to the "permanent" bracket on the sill with a single bolt and nut or wing nut.
It's designed that way to prevent theft. It allows you to easily detach the horn and take it with you, if so desired.
