Making up a list of items that need to go to the plater and wasn’t sure about a few things. On my two project vehicles should the following items be nickel plated or painted?
1927 TT:
-ignition switch plate (oval style)
-windshield pivot slides
-windshield pivot clamp nuts
-outer door handle
-inner door handle
1927 Tudor:
-door sills plates that say “Ford”
Thanks!
Nickel or not?
Nate22huckster
Topic author - Posts: 182
- First Name: Nathan
- Last Name: Fahrni
- * REQUIRED* Type and Year of Model Ts owned: 1922 huckster, 1925 tudor, 1926 TT dump truck, 1927 tudor
- Last Name: House
Re: Nickel or not?
Nathan,.. what are you calling “windshield pivot slides”? The pivot clamp nuts on both vehicles will be nickel and, if I understand you have a factory enclosed cab TT, the inner door handle will be painted.
- Last Name: Tannehill
- Board Member Since: 2002
Re: Nickel or not?
Pivot slides are plated
Nate22huckster
- Last Name: Fahrni
Re: Nickel or not?
Thanks for the info! Yes, it is a standard Ford closed cab, and by pivot slides I’m trying to describe the flat plate with a slot in it to hold the windshield in the open or closed position.
Does anyone know about the oval ignition switch panel? I’m assuming on a truck it would be less-fancy and be painted instead of nickel. What about Tudor door sills?
Thanks again
Thanks again
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Re: Nickel or not?
Oval ignition switch panel with an ammeter hole is nickel plated, oval switch without an ammeter hole is painted black.
Re: Nickel or not?
Door sill plates are usually zinc. They were nut plated on our Canadian sourced cars.
