Battery cable size
rnkugel
Topic author - Posts: 43
- First Name: Reuben
- Last Name: Kugel
- * REQUIRED* Type and Year of Model Ts owned: 1915 Touring 1926 RAJO Speedster
Battery cable size
I have read to run 1 gauge wire for my 6 volt system. However, 1 gauge is tough to find locally. I can find 2 gauge easy enough. Is anyone running 2 gauge? How does it work for you? I have been running 4 gauge, but the starter still lacks. The starter has been rebuilt. Thanks
1915 Touring
1926 RAJO Speedster
1926 RAJO Speedster
Re: Battery cable size
Have you tried a welding supply?
jagiven
- First Name: Jason
- Last Name: Given
- * REQUIRED* Type and Year of Model Ts owned: 26 Roadster, 25/26 speeder
X2 on the welding supply shop, my local shop even puts the ends on form me.
My T, struggled with starting until, I replaced the grounding cable, and installing star washers to get a better bite between the various frame members to ensure a good ground all the way back to the battery.
0 or 00 is what I use. Most good parts stores (like NAPA) might have it in stock or order the cables from the parts suppliers.
1/0 is correct
2/0 is insurance
4 ga is for emergency heat during cold weather.
2/0 is insurance
Mikey1968
- First Name: Michael
- Last Name: Jewell
I just put in brand new 2 AWG and cleaned up the area where the ground goes to the frame on my 26 Touring. Works fine for me so far.
"4 ga is for emergency heat during cold weather."
