I have a seat cushion spring that measures abour 41" wide, 16-1/2" deep and 5" high.  The back corners are more rounded than the front.  Any idea of what years of what body this may fit?  Thanks.
Keith
						Mystery seat spring?
- First Name: Keith
- Last Name: Townsend
Re: Mystery seat spring?
Pretty close to a low cowl touring front spring by the looks of it.
Call Snyder’s and give them the size and they can probably tell you. They make all kinds of T springs and have been for years.
				jab35
- Last Name: Bartsch
KW:
Here's an earlier post that might help, viewtopic.php?t=23333 Good luck, jb
- Last Name: Patrick
Does that tag on the right side tell what it’s for?
- Last Name: Strange
The dimensions you gave don't match any of the spring packs that I bought from Snyder's for my 1925 Touring body.
- First Name: Keith
Here is the tag:
Your guess is as good as mine.
The spring does NOT have the channel to crimp upholstery into.
No crimping place means it could be a back spring instead of a seat?  For a T or??
