HCCT in Penn
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
HCCT in Penn
Post by ThreePedalTapDancer » Mon Jul 25, 2022 9:48 pm
Here is a decent priced HCCT for those in driving distance of Barto Pennsylvania.
https://www.ebay.com/itm/175363350612?h ... SwwQpi3zAD
Art M
First Name: Art
Last Name: Mirtes
Re: HCCT in Penn
Post by Art M » Tue Jul 26, 2022 10:41 am
It should be worth $350 for the collectors, even if it doesn't work. However, if you are planning to actually use it, $350 will buy an ECCT which will more accurately adjust coils.
Art Mirtes
Moxie26
Last Name: Jablonski
Re: HCCT in Penn
Post by Moxie26 » Tue Jul 26, 2022 11:08 am
Monies involved in the derusting, remagnetizing the magnets, possibly a new coil ring, and then properly finishing everything off maybe worth a lot more to someone who has a great interest in an HCCT. ..... And I agree the ECCT is geared for more accurate results in calibrating and adjusting coils.
browning
First Name: David
Last Name: Kahle
* REQUIRED* Type and Year of Model Ts owned: '26 coupe, '26 touring, ‘14 Staude tractor conversion, '27 coupe, '19 roadster, ’15 speedster, '14 touring
Re: HCCT in Penn
Post by browning » Tue Jul 26, 2022 12:17 pm
I am fortunate to own two reconditioned Wilson HCCT's, one hand cranked and one with a motor, and a Strobospark. I took delivery of an ECCT just last Friday and have become a believer in just two days. I am proud to own a piece of history with the Wilsons, but am very impressed with the new tester. The two Model T's that I have "fine tuned" now idle much more smoothly. The '26 touring just ran at 49.2 mph for the first time since I got her. Her front end put up a bit of a fuss but she stayed between the ditches!
MKossor
Last Name: Kossor
Re: HCCT in Penn
Post by MKossor » Wed Jul 27, 2022 11:15 am
Thanks for sharing your experience using the ECCT. The HCCT is a wonderful example of early automotive technology but really no surprise adjusting coils for equal and consistent firing Time has distinct advantages over adjusting coils for equal coil current; after all, current is Not time and engine performance depends upon ignition Timing not coil current. Here is a simple analogy:
ECCT vs HCCT Analogy.JPG.jpg (55.7 KiB) Viewed 1423 times
