rear view mirrors
rear view mirrors
Post by Allan » Wed Aug 10, 2022 5:37 am
I had one mirror of suitable patina for Henrietta.
Now I have a pair.
I was given another head of the same dimensions, and made the brass mounting and arm to mount it. Both left and right mounting arms fit on the underside of the header board across the front top bow.
I just have to wait 50 years for the brass to age!
Mark Nunn
Last Name: Nunn
Re: rear view mirrors
Post by Mark Nunn » Wed Aug 10, 2022 8:12 am
Allan, I turned some brass parts for an old lamp. I dipped them in copper sulfate, which was advertised as a brass-ager. They matched the old brass and still look great 20 years later.
Post by TXGOAT2 » Wed Aug 10, 2022 8:27 am
Copper sulfate should do a good job of ageing brass or copper.
Post by Allan » Wed Aug 10, 2022 9:30 am
Thanks for the copper sulphate clue. Where am i likely to find it, other than a chemical supplier? Has it another use like a garden spray or something?
Southfork Creek
Last Name: Wightman
Post by Southfork Creek » Wed Aug 10, 2022 10:08 am
Any jewelry supply store sells Jax. They make many different solutions to tone all different metals, brass, silver, copper etc. It comes in small or large bottles. To tone model t brass, I personally use the Jax Brass toner for Brown Finish. There is also a brass solution with a blacker finish if you want it darker. You put in on one or more times, wash with water, and you are done, or then polish lightly until you are please with the final finish look. It's fun. I have gotten carried away and even done entire new brass radtiors for "original" cars.
Post by TRDxB2 » Wed Aug 10, 2022 11:33 am
Copper sulphate is a used on most septic system root cleaners and cheaper than the pure form. Can be used to kill a tree stump too. Also, I came across an copper electroplate method using it :o https://www.youtube.com/watch?v=T3qhqTVssoo
There are many brands check the ingredients
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Wed Aug 10, 2022 1:37 pm
I bought a bottle of copper sulfate solution from a well-stocked woodworking company. It's not hard to find at home centers in the US. It's is also used to control algae in ponds. I don't know about availability in Australia.
Post by Allan » Wed Aug 10, 2022 7:47 pm
Thanks fellows. i know a pond cleaner and a plumber, so I should be set.
