Hey guys, can anyone tell me that the bolt size is for the 4 bolts that bolt the torque tube to the hogshead are please? 1926 Model T coupe.
Thanks,
Bolt size
Topic author - Posts: 89
- First Name: Shawn
- Last Name: Barnard
- * REQUIRED* Type and Year of Model Ts owned: 1926 coupe
- First Name: Adrian
- Last Name: Whiteman
Re: Bolt size
Hi Shawn, we have bolt charts available on the site: https://mtfca.com/phpBB3/app.php/gallery/album/195 which will give you most bolt (and nut) sizes.
The one you want is: https://mtfca.com/phpBB3/app.php/gallery/image/1501
and you are looking for a 3/8" UNF 13/16" long
Re: Bolt size
This may be of interest as well:
https://mtfca.com/phpBB3/app.php/gallery/image/1604 and https://mtfca.com/phpBB3/app.php/gallery/image/1784
- Last Name: Gould
Re: Bolt size
3/8 x 24 tpi, same as engine to pan bolts.
The holes in the pan are tapped for 24 tpi. Check it out
Re: Bolt size
The two bottom ones are shorter, threading directly into the pan. The two upper ones are a bit longer, going through the holes in the hogshead and then getting castle nuts and cotter pins (although a lot of people shortcut with lock washers?).
I don't recall the actual lengths (pretty easy to figure what fits best?).
- First Name: Shawn
Re: Bolt size
Thanks everyone that really helped. I bagged and tagged everything but I can't find these ones. I'm sure they are somewhere safe.
