Tie rod question
Craig E. Luton
First Name: Craig
Last Name: Luton
* REQUIRED* Type and Year of Model Ts owned: 1914 Ford Runabout; 1915 Ford Touring; 1936 Ford Pick-up
Tie rod question
Post by Craig E. Luton » Fri Aug 19, 2022 9:33 pm
What year did Ford change the tie rod from the ball being attached to the tie rod itself to the ball being attached to the threaded adjuster that screws onto the end of the tie rod? The parts book lists the same part number form 1909 all the way through to 1927.
Thank you; Craig
Re: Tie rod question
Post by RajoRacer » Fri Aug 19, 2022 9:55 pm
The Encyclopedia states 1918 for the change.
Post by Allan » Sat Aug 20, 2022 4:12 am
There was later change to the detachable ball too. Early ones were not tapered like those used later. I have no idea when this change occurred.
Post by RajoRacer » Sat Aug 20, 2022 11:52 am
According to the listed parts, straight shank ball was '19 - '21 then the remainder of production was the tapered shank ball.
